What is a Question?
Questions are a super-easy way to get answers from the Instructables community. Learn how to build, do, or make anything! You just ask a question and the community will provide answers. You choose the best answer!
Submit a Forum Topic! The forums are the place to ask questions, share a cool project from another site, find collaborators for your latest project, or discuss anything of interest to the Instructables community.
Do you have a lot of images to upload?
If you prefer to upload your images before you submit, then this is for you.
Remember to tag them so they will be easier for you to find when you are viewing your library.
You can also upload images when you are creating your posts.
Did you find a bug or have a suggestion for us?
We appreciate all the help our users give us in tracking down bugs and making the site better for everyone.
PhotosPhotos
Build the circuit based on the diagram. I cut my IC board with a dremel to make it smaller so there was enough room in the box along with the 9 v battery.
hi, your skematic works well with led or buzzer for example but doesent activate relay for some reason, somebody noted that its AC and for that the realy doesent work. i tried to convert it to DC with four diods but this didnt help either. can somebody please help ?
yeah the box with the arrow is the variable resistor the arrow would be the middle connection on the variable resistor they are 3 terminals use on of the outer ones and the middle one
Hi people, I have tried to make the circuit but it doesn't work i'm not that good witch schematics, can someone help me please. i have linked all the parts like this:
The Schematic makes no sense. It is suggesting that there is always 9v tied to the base of the transistor. This will not only hurt the transistor, as there is no protective resistor, bit it renders the entire photo resistor divider circuit useless.
I would like to know if anyone has actually got this thing working using Kipkays plans to turn on when the beam is broken and turn off after a few seconds.
i have a question about the wiring of one of the components. the 5k variable resistor has three pins, that i understand. but wat is teh point of connecting two of the pins together, like in the schematic. this is something i have not understood for a while now.
Can you replace the piezoelectric buzzer with a relay switch to activate another circuit? What modifications you would need to make the relay work. I only need the relay to work for a very short time to activate another alarm system.
If the signal going across that line activates a piezo, it will be ac....make sure your relay is not DC activated (as most are) or you'll get a lot of chatter from it.
understand the patter so you will done working! but if not really understand ask your friend or if you have a friend experts in electronic cybertronic ask him what to do and what the meaning of the circuit pattern so you will know how to make!! so very well thats only my help because im done of this instructable ^_^.. bye2x....
Hi, can someone please explain how the circuit is wired together. Im not too good with schematics but im sure if someone could explain it more in depth (dumb it down a bit) i could do it. Pictures would be great and helpful too but not necessary. Thanks.
skematics are great once you learn how to use them here are pictures should help you with more complicated parts remember all grounds to negative also try buying a breadboard if you don't have one they help alot also all the wires on that circle that say +9 volts go to positive end of the battery hope this helps.
this circuit haunts me sometimes. i know that when the laser isn't shined at the photocell, it activates the circuit, and the resulting sound alternates loud adn quieter pretty quickly. i've looked at the circuit a dozen times, but i just cant figure out HOW it all works, how the componants influence everything. CAN ANYONE EXPLAIN THIS TO ME???!!!
I'm from Brasil, I did the same project, but doesn't worked, kip sorry, but yours circuit is confusing, Can you explain or post a new diagram? thanks for everything
if you wont the circuit to detect darkness instead swap the ldr and variable resistor places
sorry
I dont can make this
please anybody sand a good picture PPPPPLLLEEEEEEEEAAAAAAASSSSSSSSSSSSS
they are when you know how to draw thewm properly
this skematic is wrong
This appears to be the one he used:
parts.digikey.com/1/parts-kws/20-turn-potentiometer
Frys should definitely have these.
bye2x....
