3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Protect the Tech
Step 4Optional step - skip if you're going strapless
Optional step - skip if you\
If you want a strap/handle for your caddy place the cord you cut earlier on the face side of one of the pockets. Put the ends in one of the upper corners, with the raw ends of the cord coming off to the side. The raw edges should be lined up against the raw edge of the pocket unless, like me, you cut out your pocket with too much extra material on the sides. In this case they should be just inside, as the picture shows.
Pin the edges here, one next to the other. Make sure that you leave the pins sticking out far enough from the edges as shown, so you will still be able to see them in the next step. DO NOT pin the strap edges on top of each other. Most sewing machines can not handle that kind of thickness and you will end up with a broken needle or worse.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:sagefemme
