Step 4Paint and Assembly
Insert all the components through their respective holes and affix with nuts. The small wire pin holes will need to be cut to shape with wire cutters and hot-glued in place from beneath.
Solder all the connectors and things together according to the schematic from Step 2.
Plug in 9V from a wall adapter and hit the footswitch, you should see the LED turn on and a voltmeter will show that 9V exists on the binding posts. If so, great job!
Unplug the unit and screw the two halves together. You're done!
Add Comment
