Prototype Candle
3,873
10
11
Published
Introduction: Prototype Candle
This is a prototype product i made for innovate class. This product is a candle with a readily available matchsticks and the brown thingy where you strike your match sticks to make them light. how did i do it you might ask? well here is a step by step detail:
1. Find a candle(must be a bit big and wide)
2. Prepare scissors, glue/paste or even double sided tape, and small screw driver or philips
3. Get a match box and cut the brown thing, also get at least two matchsticks
4. Drill the sides of the candle using the philips or screw driver until all of the head of the matchsticks are completely hidden. (I only recommended drilling two holes, you may drill more if you want to)
5. Use paste/glue or double sided tape to stick the brown thing to the candle (choose location)
6. Let the glue/paste dry
7. Insert the matchsticks
8.Your done!
Step 1: Normal Looking Candle
normal looking candle
Step 2: Top View
Top view of candle
Step 3: Finished Product
This is what the finish product looks like after doing all the steps :)
    • Oil Contest
      Oil Contest
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    11 Comments
    a bit simple, would be better if you could put some sand paper in the hole so that the matches lit wen you pulled them out of the candle
    Oh sorry, didn't read your comment first, always had that idea but never tried think i will now
    May i surgest that if your going to this much effort, why not cut the brown thing up and glue it inside the holes so when you take a match out you light it. -Cheers, Chris
    A few construction shots would have been helpful, as well as a description of intended use (and market, if it's for an innovate class).
    hello to all!
    this is a school project currently still under construction.. sorry for the crappy pictures which was taken from a classmate's cellphone.
    will fix this instructable when i have time... my thanks for the comments guys!
    thanks pyelitegamerro76 for somewhat explaining :)
    thanks also to GorillazMiko!
    he added 2 matches and a striker to the candle so it is easier to light the candle
    i get it
    He glued sandpaper to a candle. A detailed write-up could only make this more painfully terrible.
    Make this into a slideshow, or explain how it was made.
    ?????? explain
