This is how you can make a Hover floating style platform easily and cheaply. The main body of the unit is made from MDF (Craftwood) and a tarpaulin, and uses a portable battery powered blower vac to provide the air.
You can get up to 6 small children on there easily.
Remove these ads by
Signing UpStep 1: Description of the Build
Cut out two circles of MDF - one being a full circle and the other a ring. Wrap the tarpaulin over the ring and staple it to the other side.Trim off the excess tarpaulin.
Drill a hole in the full circle piece to let the air in. Then, screw the ring to the full circle piece trapping the stapled edge between the pieces of wood.
Cut out a small round piece of wood and screw into the center of the tarpaulin side. Then, cut about 6 small holes just outside of the piece you just screwed in.
Fit a nozzle flange on the other side over the small hole you drilled for the air to go in (see step 2).
Attach the blower to the nozzle flange and power up. The platform should lift off the ground and hold your weight.
Visit Our Store »
Go Pro Today »
I am part of a maker/hackerspace and we are thinking of a hover bowling competition between some other spaces near by.
The idea is to make some large cardboard or foam bowling pins and use ourselves on the hover craft as the balls.
should be fun, but gas blowers are temperamental and corded blowers are well corded.
14.4V and 2.6 m3/min air flow which is 92 CFM.
Lol. Sounds like a great game.
They seem to work ok for me.
Try a different browsers. eg google chrome etc
We built this 7 times for a show on the weekend. Everybody loved it.
The ring in the middle makes a half donut shape on the outside which makes a small edge for air to get trapped and ride on.
A larger one can lift a lot more weight you just need a powerful blower.
can atleast be used lol haha
however, he used a gas powered blower. It was pretty cool.
This one I made has worked great for years:
http://www.youtube.com/watch?feature=player_embedded&v=ldzBo1yrG0c
...but it uses a good-sized Shop-Vac and is tethered by a power cord (which I use to fling passengers around). The next step on this one was going to be a gas-powered blower, but maybe I'll have to rethink after seeing this 'ible! The really hardcore hovercrafts use the engine/prop from an ultralight plane, but now you've got me wondering about battery-operated possibilities...
Thanks, and nice work!
