3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Prototype Wind Turbine VAWT Home Hydrogen Production
  • last photo ←
   This was an interesting project, which has potential in the future, but did not deliver desired results.  The idea was to make a vertical axis wind turbine (VAWT) that instead of charging a battery, would deliver its power directly to an electrolysis apparatus to make hydrogen and oxygen gas.  The reason for doing this would be to avoid the complications and expenses of inverters, batteries, and connecting the turbine to the grid.  It would also make hydrogen gas which could power a car, a generator, or be used as a welding/cutting torch, which is what I intended to use it for.
   That was the idea, however I rarely saw the turbine actually spinning, and it never caught and converted enough energy during its few months of operation before winter to produce any noticeable amount of hydrogen in the collector.
   To make the turbine, I cut a large plastic jar in half using a razor blade and my Dremel rotary tool.  The two halves were offset to create a sort of "S" shape to catch wind from all directions and bolted to a piece of plastic cut from the housing of a salvaged non-working computer scanner.  A small piece of polypropylene tube was used to connect the piece of plastic at the bottom of the turbine to a small gear usinjg JB Weld.  The small gear slid perfectly onto a small DC motor salvaged from the same computer scanner as the piece of plastic.  The DC motor was screwed to the lid of an applesauce jar with hot glue placed over to screws to help prevent moisture from getting inside the jar.  A long wire salvaged from a broken vacuum cleaner was attached to the leads of the DC motor and connected to the electrolysis apparatus.
   The electrolysis apparatus consisted of two thin stainless steel sheets spaced apart roughly 1/16 of an inch.  One sheet was connected to one lead coming from the DC motor, and the other sheet was connected to the other lead.  This way, when the wind blows, the turbine would spin, creating electricity through the DC motor, which would pass through the water, breaking it into hydrogen and oxygen.  The gases were collected in an inverted water-filled bottle.
   Image notes have more information.
   I may revisist this project in the future, but in my suburban area and a mother that doesn't want anything on the roof, wind power is hard to harness.  It was a fun project, and one that may have potential in the future.  Thanks for reading!!
26 comments
Apr 16, 2012. 6:43 AMgabdab says:
How do you store the hydrogen for later use ?
I would concentrare on finding a suitable tank , if one exists yet , which guarantee a safe use of the hydrogen.
Wouldn't it be safer to look into flywheels (made of concrete for example-cheaper) for energy storage (from a wind turbine) ?
Feb 1, 2011. 7:51 PMhexedene says:
The concept is great! Does the electrolysis apparatus work if the turbine is spun fast enough? Do you only need to upgrade the turbine for better performance in order for the project to produce more hydrogen and oxygen?
Feb 2, 2011. 7:07 AMKiteman says:
Yes, the effectiveness of electrolysis is largely influenced by voltage - I would be surprised if this set-up put out more than a volt or two.
A larger-scale test is definitely recommended.
Mar 4, 2012. 10:17 AMzagrot says:
There is a minimum voltage required to perform electrolysis; my chemistry book says 1.42v, but the rate of gas production is a function of amperage. Simply put, more current causes more gas to evolve at the electrodes. You would do well to talk to your school's chemistry teacher about your project. Make sure you have some type of electrolyte, table salt works well (a level teaspoon would suffice).
Overall, this is an interesting method of energy storage. Keep up the good work.
Mar 19, 2012. 5:02 AMjohngill says:
Hi,
RE:"Make sure you have some type of electrolyte, table salt works well (a level teaspoon would suffice)."
I would tend not to use table salt as an electrolyte because of other discharge gases during electrolysis, try a weak solution of Potassium Hydroxide from your Garden Center. I think it's known as "PotAsh" ? Add the Potassium Hydroxide slowly to your warn electrolyte water and note the current drawn from your power source. Too much current will only heat the solution up and even boil it away. Granted, more current will produce more "HydrOxy" gas but careful balancing is the name of the game for good efficiency.
It's also worth noting that combined "Hydrogen-Oxygen" electrolized gas mix (HydrOxy) implodes very loudly upon ignition........... TAKE CARE
Above is offered in good faith and without predjudice.
John
Feb 2, 2011. 6:18 AMiPodGuy says:
I would like to know this as well.
Feb 6, 2012. 8:18 AMsilpol says:
I like the way you keep hydrogen-production electrophoresis system in less than meter from gas storage under BBQ - it gives some hope one day you will review your own safety rules.
Feb 3, 2011. 2:02 PMpdionne says:
To use the wind more efficiently, double the number of wind collectors, barrel halves, and stack them twice as high. using a compass to describe placement, the lower two sections would be mounted North and South, and the top two would be mounted East and west. This would cause the generator to spin faster, no matter the direction of the wind.
Some have questioned why this would work better than a blade turbine, look at the overall surface area of the wind collector. this type unit will produce a higher output with a lower required air speed, and may even need to be restricted to prevent it from going too fast.
I've seen units similar in design, that were impossible to stop manually and had to have a disc brake system installed to stop it, even with just a slight breeze blowing.
Feb 3, 2011. 9:37 PMpdionne says:
Half of the collectors will be facing into some part of the wind at all times, and the other half will be in the vacuum portion of the unit on their return to the windward side. They would have very little drag, unless there is a sudden wind change. Even then they will produce more than a standard wind turbine because these always have collectors facing in whatever direction the wind is blowing from.
My Solar Design Prof at USM built the one that couldn't be stopped. He used a different design, but the same principle. A student tried to stop it when there was just a slight breeze, using a huge pipe wrench, and the power of the thing broke both of his arms. Next they tried a big chain the was covered with radiator hose and it snapped the chain. So, we built a brake assembly using disk brake pads, mounted to a frame near the drive pipe, and finally stopped it by compressing the pads against the pipe. The pads were about work out when it finally stopped. Before we set it free again, we installed a heavy duty hydraulic brake assembly on the pipe with a push pedal that worked fine, but still had to work stopping it.
We did some really off the wall building in that program. For my final project I designed a house that could be heated to 70 degrees with it -30 outside, and all it used was the same amount of heat as what a book of matches produces per hour. The Prof said it couldn't be done, and I'm one of those people who can make anything work. My nickname in the military was The Wizard, so that should tell you how I am.
Apr 27, 2011. 6:15 PMthereuters1986 says:
As far as braking/slowing the turbine down wouldn't a tarp placed between the turbine and wind work? A "wind-breaker" if you will. Design a cowling that will be horizontal and below the turbine when not used. Then transformed into vertical to shroud the turbine to help braking. Just a thought.
Feb 7, 2011. 5:55 PMjoshsimerman says:
Pdionne, could you post a link to a document or something that shows more details on what your professor designed??
Also, I would be really interested to learn how your house heating worked? Was it thermal mass and south facing windows, for passive solar or more advanced than that?
Thanks
Feb 7, 2011. 8:23 PMpdionne says:
The house was 24 X 50, with the 50 length of one wall facing south. The other three walls were bermed up to roof level. The south facing wall was covered with dark brick to absorb the thermal radiation from the sun. Looking at the southern wall, the left half of it , and to a depth of 10 feet into the house, was a sun room with triple pane glass sliding doors. The room had dark tile for the floor, and water storage tubes along the back wall to act as thermal mass and store the heat. There was a intake vent at the top that was used to circulate the heat through the house. When the sun reached a certain point, where the rays no longer served the purpose of producing heat, insulated curtains would automatically unroll, thereby preventing the stored heat from being lost through the glass. The remainder of the south facing wall had the main door and a mud room that extended out from the house. There was also another door that went into the kitchen.
As I said before, the other walls had dirt against them that was even with the roof. I put a roof on the house, but built on the roof was was an area that some people call a captains deck. It is a fenced in area in the center of the roof, where you gain access to it from a stairway inside the house. What it does is gives you an area where during the summer you can go up there to relax. The other advantage is that because of the walls being bermed, and because the frost line will only be three feet down, the ramainder of the wall will be exposed to dirt that will stay at 50deg all year. So when it comes to heating, you only need to raise the inside temp 20deg, and during the summer you will still need to draw warm air in to bring the temp up where it is comfortable.
One of the drawbacks is that a dehumidifier would be needed year round as it would be a perfect breeding ground for mold. I was also going to use a solar water heater to heat the water and pv panels for the electricity. It was a really simple design, but I still had to put in a sizable amount of insulation to help with keeping a barrier between the house and the cold dirt.
The wind unit is pretty hard to describe, so give me a couple of days and I'll scetch it out for you and will send it that way.
May 2, 2012. 12:40 AMnicstix says:
A year later, I would love that wind turbine idea ;)
Feb 8, 2011. 6:39 AMjoshsimerman says:
Nice design. That sounds exactly like an Earthship (http://earthship.com/buildings/global). I think that they have gotten it to a point where it is sealed enough not to need a dehumidifier.
Do you happen to remember the design or an specifics to the shape of the blades for the turbine that wouldn't stop? That sounds like a perfect companion to an earth home.
Feb 5, 2011. 8:44 PMpdionne says:
You would be able to make a medium sized one and connect the stand to the corner support post for your deck. As long as you take time to get all of the collectors positioned properly you shouldn't have a problem with vibration. Also, if you set it up with a belt drive to the generator, you won't have a noise issue.
There are tons of pros to this design.
Feb 2, 2011. 1:19 PMsquishoso says:
Maybe using a pin-wheel-like design for the wind turbine and a weathercock-like design to keep it aligned it to the wind? And making lots of those to increase wind caption area, instead of making it higher?
Feb 2, 2011. 7:46 AMrimar2000 says:
VAWT has the problem that they use only a half of the wind. I think that problem can be solved using a half screen "tail driven". It is to say, a tail that can rotate around the same axis, and at front of the VAWT a semi-screen facing the idle side of the turbine. Pardon my "yes bwana" English.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
52
Author:fozzy13
Hey everyone. I am currently a high school student who enjoys a wide variety of hobbies. At school I am on the wrestling team and am in many honors classes. I do judo outside of school. I like to b...
more »
