Prototyping a Marketable Product Using Blender 3D Open Source Animation Software
Published
Introduction: Prototyping a Marketable Product Using Blender 3D Open Source Animation Software
About: I'm the kind of person who's mind doesn't stop. Literally, I take medication to fix that just so I can sleep at night. I have an unhealthy obsession with making things and believe, firmly, in sharing what I ...
This is a project I've been working on is called the U.S.C.Etch (pronounced you-sketch) which is short for Universal Surface Compound Etcher, and is a tool designed to etch on any surface using chemical free, micro abrasive etchant. It's based on an instructable for a glass etching tool, that I'd created some time ago. When I first created the instructable, I was simply trying to create a cost effective version of a different tool, but as I progressed, I saw that there was serious room for improvement in the design, to give it more control and functionality as well as aesthetics. I also wanted to make it modular, in that it could be upgraded or repaired without any mechanical skill. This meant designing it with external parts that could be removed or replaced without the use of special tools or technical knowledge. Finally, It needed to be comfortable, incorporating a pistol shape for rough work, and pen shaped for fine detail, allowing for a greater range of movement. I had a lot of work ahead of me, so with that, I set to prototyping.
When you're prototyping a potential marketable product, it can be difficult if you don't have the facilities or resources to create your finished design. You may have a vision in your mind, but the reality is that a real world application of your design may not be feasible, especially if your working prototype doesn't bear a resemblance to your envisioned product. You need a way to test form and function and to ensure that parts will fit where you want them to fit without having to shoehorn them into place because of bad planning, ruining the overall form and severely altering your imagined design.
Step 1: Tools and Supplies
This is a side by side physical/virtual build where function is created in the workshop and form is created on the computer screen. This allows for real world testing and application, of your design, while ensuring that overall design spec. conforms to your predetermined vision of your project.
Tools;
  • Blender 3D Open Source Animation Software - You can download Blender for free from here; Blender 3D
  • Workshop - You need a location to prototype
  • External Learning Resources - I'll cover that in the next step
Supplies;
  • Parts for your prototype
  • Printer/paper - Hardcopy of your 3d design for workshop reference
Step 2: Planning Your Prototype
Software Considerations;
Step 1, as always is knowing what you want to build. Traditionally, before I start a project I've always drawn it out in Windows Paint. Yes...I DO use windows paint, but for the reason that its relatively simple to use and and can give you a quick hardcopy of the design in your mind.
An update to that, is to use Autodesk Sketchbook, which is available in the Google Play Store and the App Store. This is a huge advantage since you can edit your design on the fly, and upload it to the cloud, accessing it from any device. It's particularly useful in that it doesn't tie you down to one computer, allowing you to work on it anywhere you may be, while affording you the ability to show anyone your project on the fly.
Gathering Supplies;
This is the third prototype I've created, and easily the most complex. As a process, I tend to gather parts, needed or not, into huge bins for potential use. Essentially, by the time construction happens I've picked multiples of each projected piece. I.E. If I need a hose, I'll get 6 different hoses. If I need valve, I'll grab six of those. etc. Parts I can't find, or purchase locally I'll build, but plan for their commercially manufactured part in the final design.
Step 3: Learning How to Use Blender
The learning curve, for a new piece of software can be pretty steep, especially when you're learning to manipulate objects in a 3D environment. Initially, I was overwhelmed trying to learn as much as I could about Blender's workings and was near quitting until I had a bit of a revelation. I realized that I didn't need to understand all of Blender, only the parts that I would need to create my project.
Each part and piece became a different tutorial. If I needed a chrome bottle, I'd research Youtube for a blender project that created a chrome bottle. If I needed a hose, I'd find a video on creating hoses. If I wanted a rotating camera, there was a video for that as well. Breaking down my project like this meant that the only thing I truly had to commit to memory were the keys needed to navigate the 3D world. Everything else could be researched on the fly and applied as necessary.
Here's a link to one Youtube user named tutor4u that created some of the most useful tutorials for me. His realistic chain video taught me the process of chroming, and the ice video came in handy when I was trying to create transparent hoses. Interestingly, the creation of the hose itself is based on the handle of his coffee mug tutorial that uses a curve path to create a rough shape then change its geometry to the preferred shape.
Step 4: Cycles Render VS. Blender Render
This is a matter of personal preference, but it's essential that you decide which you're going to use prior to starting your Blender project. As a matter of opinion, I'd suggest using cycles render as much of the tutorials I've recommended, thus far, rely on that render option. Likewise, many of the free textures and models I've come across use cycles render and so it presented a more logical choice for my project.
Here's a link that will explain in greater detail the differences between the two; http://blender.stackexchange.com/questions/5820/how-is-cycles-different-from-blender-internal
Whatever render option you choose, you will need to stick to it throughout your project so I'd suggest exploring what you would like your final prototype model to look like, and go from there.
Step 5: Models and Textures
There are plenty of videos, online, that will teach you how to create your own textures using Blender's resources and/or photographs of your choosing. As mentioned before, the texture for the hoses in my etching tool model were based on the ice tutorial created by tutor4u's Youtube channel. This can be a time consuming process, however it does add some individuality to your project.
Luckily, there are plenty of resources, available, that offer free 3D Models that you can use in your project, or textures that you can use to skin it. One of the most useful sites I've found is called 3D Cadnav, and hosts hundreds of models and textures that you can download for free.
Step 6: Details, Details, Details
Though it's the outward appearance that most will see, it's important, in your 3D model that you detail all of the workings, and not just the exterior textured image. Parts that are internal to your prototype are especially important as you'll need to see how they fit into your finished design, and not end up surprised, later on should you have made a mistake in planning.
As you can see in the image, I've blocked some of the more important parts (the mixing chamber) of my project from view by texturing over them. That's because it is an extremely unique design that I don't want to display openly just yet, or at least until the final prototype is built. However, you'll notice that many of the internals are in place, with a few left to be created. In the final model, all of the internals will be visible in the wireframe for a detailed construction of the prototype.
Inevitably, this will leave less room for error in the final build.
Step 7: Final Thoughts
Through the process of physical/virtual prototyping there's the advantage of having a working model of your project, with a virtual representation of its final form The advantage being that design issues are dealt with before the final prototype is produced and not surprising you down the line, potentially jeopardizing your project.
As mentioned in the beginning, this is an ongoing project with the inevitable goal of creating kickstarter campaign to elicit funds to further my work. Unlike many campaigns, it isn't simply a virtual (and often impractical) idea that attains funding, but ends up disappearing into the woodwork, never to be seen again, which seems to be a real issue these days.
Having a working/virtual prototype tells potential investors that you have an idea, you've developed it fully, but have also ironed out all of the details ensuring a seamless progression into production, leaving nothing to chance.
As usual, I hope you've enjoyed the instructable. Thanks for following.
    • Water Contest
      Water Contest
    • Oil Contest
      Oil Contest
    • Creative Misuse Contest
    7 Discussions
    can you buy U.S.C.Etch this yet? If so how much isit
    Couldn't get enough backing, unfortunately. We found a machine shop to product the parts, but the backer I lined up pulled out at the last minute. I opened a vape shop a while back and it ended up on the back burners, but I do keep coming back to it now and then.
    Good luck I hope it hits the market one of these days. I was ready to buy one.
    Happy New Year
    Do you have an IP or patent protection on this? If you want to make this into a product I'd recommend it.
    Mostly pending. It's a lot of work...and money, to say the least, but definitely in process. I find it hard to get out of the workshop and sit behind a desk sometimes so that slows things down, especially since I'm constantly tweaking and improving the prototype.
    Awesome! Just seeing this gave me one of those "Aha!" moments (albeit on an very oblique venture) -thanks for sharing!
    I don't know squat about 3D programming, and can't afford the learning curve timeframe, but I sure like the look of what you've got here. I especially like the use of what appears to be weedeater and scooter fuel line!
    You nailed the esthetics perfectly! And I do hope you get kickstarted!!
    A few years ago I worked in a metal factory and could purchase any scrap at 19 cents a pound. The last day i worked there i wrote a check for $410.00 worth of 'scrap.' Much of that scrap was stuff scavanged from a metal cutting laser unit with a large bed. It had been replaced by a brand new unit, but the old one was a top-grade german unit with the main controllers housed in a beautiful Bosch cabinet. The table and cutting head had already been dumped into a 40 yard dumpster before I learned it was being scrapped, so my ability to cannibalize was limited by having to weigh-out all high pucker-factor dives and, well, sadly I had to concede some goodies just weren't worth getting crushed for (though i was willing to accept the possibility of crapping my pants). I spent many breaks and lunches removing goodies or planning my next attack. I cobbled onto all things pneumatic, 24v controlled air-valves, controllers, miniature 1/4" tubing quick connects, air cylinders, precision rails and their mating bearings -you name it! I walked away with a fortune of components that would have otherwise remained always out of reach for me.
    I gutted (and saved) the cabinet of all the terminal boards, transformers and panel mounts the first year, but removing all the ionic grime wasn't concluded until the next year. I'm older, so it has been slow going, but around Christmas I moved the cabinet inside (here in my living room!) to begin conversions for a mobile air-brush station for fairs and carnivals.
    Possibilities for the other stuff is something I've continued to find staggering. But not so much now. Thank you for open-sourcing your ideas and inspiring talents. It's weird how seeing something can touch and inspire! Again, thanks and good luck!
    Thank you. I do appreciate the praise. I'm guessing you realize, from your dumpster diving experience, how difficult it can be to create a startup. I was hoping that my instructable would get more exposure by being featured, however the number of folks who have seen it, so far, is perfectly fine for me. It's my goal to try and get one of these units into every tool box. Visualize a micro etcher that can be used for everything from glass to stainless steel, and be treated as a sandblaster or as an artists pencil. Most of the innovation is in the mixing chamber in the tip while the final product will come with different tips for different effects. Again, thank you for the praise and good luck to you as well.
