Psycho Scooter Scramble by randofo
Featured
Psycho Scooter Scramble is a blind-driving electric wheelchair game. It consists of two riders, strapped into electric wheelchairs, and two blindfolded pilots, who remotely control the wheelchairs from the sidelines based on information given over headset by their driver.
The basic mechanic is simple: players must drive across the court to get a ball from a stand, then drive back across to put the ball in a
hoop. This action is repeated until all four balls have been scored or the timer runs out.
Since there is an inevitable disconnect between the pilots’ steering and their teammates’ intentions, wheelchairs zigzag across the court at high speeds, colliding with each other, ball stands, the scoreboard, and most everything else; all the while, taking full advantage of the custom steel bumpers.
Psycho Scooter Scramble was created for the Creation Challenge. Team Instructables includes Amanda Ghassaei, Audrey Love, Eric Wilhelm, Gabriella Levine, Greg Johnson, Jake Rogers, Jessy Ellenberger, Matthew Dalton, Noah Weinstein, and Randy Sarafan.
Step 1: Go get stuff
You will need:
per cart**:
(x2) electric wheelchair
(x1) 1"x1"x10' square steel stock
(x1) 2.5"x.175"x20' steel flat bars
(x1) Arduino
(x1) Wireless SD Shield
(x1) Xbee S1
(x1) PC Board
(X12) male header pins
(x4) relays
(x4) 2K resistors
(x4) 1K resistors
(x4) 5.1K resistors
(x1) 9V battery connector
(x1) 9V battery
(x1) 22 AWG stranded wire
(x1) wireless headset
(x1) Large-ish sealable plastic food container
(x1) assorted zip ties
control pedestals:
(x1) Arduino
(x1) Xbee
(x1) 9V battery
(x1) 4' x 8' sheet 3/4"wood
(x2) floor flanges
(x2) 1/2" threaded metal pipe
(x2) 24" x 24" acrylic sheet
scoreboard:
(x1) 4' x 8' x 3/4" plywood sheet
(x4) flanges
(x2) 48" threaded pipe
(x2) threaded nipples
(x2) elbow joints
(x2) small whiteboards
(x4) 36 x 24" 1/8" black acrylic sheet
(x2) 36" x 24" x 1/8" orange acrylic sheet (for lettering)
(x2) 12" 7-segment display
(x1) Arduino
(x1) Annoying buzzer
(x1) Light-up stop hand
(x1) Red arcade button
(x1) green arcade button
(x1) PC Board
(x1) 5V relay
(x1) 5V / 120V 10A solid state relay
(x2) giant 7 seg display
(x2 darlington uln2803
goal:
(x1) 8' x 4' x 3/4" plywood board
(x2) Basketball nets
(x1) Staple gun
ball holders:
(x8) Kick balls
(x2) 4' x 8' plywood sheet
(x2) 4x4 wood beam
(x4) 2x4 across
(x1) 20' thin metal rod
miscellaneous:
(x2) referee shirts
(x2) whistles
(x1) 1 yard of bright orange fabric
(x1) 3' dowel rods
**Cart materials are for ideal conditions. Parts may vary depending on the electric wheelchair you are confronted with.
1-40 of 48Next »
shtranka says: May 16, 2013. 3:30 AM
thank you,and in my project i will leave the joystick connected ann add the arduino, but if both of them are working , is that a problem, if yes any solution to keep only one of them working
shtranka says: May 13, 2013. 5:34 AM
hi , i just want to know if you used a transistor to command the relays or what!
amandaghassaei says: May 15, 2013. 2:44 PM
the relays are connected directly to the arduino digital output pins
shtranka says: May 9, 2013. 1:36 PM
hi, i m going to command a wheel chair using arduino but i can.t figure how did u make the connection between the arduino and the relays?? don.t you need uln 2803 and potentiometrs to deliver the values required? and i'l use arduino DUE is that possible ? because i 'll use a 5v sensors that can.t handle. so would you plz help me up by explainning the circuit you add to the arduino and wich pins did you used. thanks :)
the relays we used operate on 5V, so no need to use a uln2803. looks like the due only outputs 3.3, this will not work with the 5v relays. I would recommend using an uno. the schematic is in the step.
dany151 says: Mar 21, 2013. 7:50 AM
hey ...my wheelchair run very fast ... i made as mentioned in your project...anyway to make it slower ?
amandaghassaei says: May 15, 2013. 2:42 PM
change the values of the resistors so that the voltage going into the wheelchair control is closer to 2.5V
uneakone says: Feb 15, 2013. 7:31 PM
Hi all,I know I'm getting to this project a bit late, but I have been trying to figure out what I am doing wrong. If anyone can get me pointed in the right direction I would greatly appreciate it. This is what I have.... I built up the circuit board with the total of 4 relays on it. From the joystick I have the plus voltage going to the 5 volt pin on the sending arduino, the minus ( or negative) going to the gnd pin on the same arduino. I also have one of the signal left/right pins going to analog A0, and one of the signal forward/reverse pins going to analog A1.
For the Receving arduino board combined with the circuit board I made I'm having trouble with the hook up. I thought the output of pins 4,5,6,7 would ave gone to the relay + and the negative woud go to the arduino gnd, but with this hookup when I toggle the joystick all the relays seem to go on so I know that's not right. I also have the Receving arduino + 5 volt going to the + side of the two 2K resistors, and the gnd to the - side of the other two resistors.
When I plug everything in I do get a reading of 2.5 volts on all four signal pins referenced to the gnd pin on the arduino which is tied to the negative side of the relay.
When I toggle forward I get 1.2volts on both of the forward/reverse signals, and the left/right signals increase to around 2.6 volts. When I toggle reverse I get 3.8 volts on both of the forward/reverse signals and again the left/ right pin voltages increase slightly. Do I have any of the connections right? The controller that my chair came with is a dynamic DL 5.2i so it only has 6 wires going to the joystick (4 directions and +/-.) hopefully someone out there has some experience with this type of controller.
Thanks Kim
dany151 says: Dec 30, 2012. 2:05 AM
Dear amanda
do you mind if add my code for control the wheelchair ?
Raynentye says: Dec 17, 2012. 2:07 PM
I decided to try this out seeing as how I have a powered wheelchair that was given to me. I'm having a problem with the Center Tap pin. On your diagram it says, "Might need 1K -2 K". I've tried practically every resistor in between with no success. Every time I turn on the chair it gives me a "Joy Stick not centered" warning and doesn't allow me to move the chair. Any luck with a particular resistance? I was thinking on trying a 3K ohm potentiometer adjusted to equal resistance and voltage balancing. Any assistance would be greatly appreciated!
dany151 says: Dec 18, 2012. 3:27 AM
Raynentye
you can solve it by using different resistors...like 1K and variable resistor for the center
1K====>--(measure voltage here)--<==== variable resistor
then change the value of the variable resistor until get 2.5v
Raynentye says: Dec 18, 2012. 1:10 PM
I pulled apart my breadboard in a tiresome rage last night and took a nap. I then decided to attempt a "parallel re-engineering" attempt. Took some measurements on the main joystick and viola! I came up with this:
I have two joysticks for my wheelchair: the primary for the person who is in need of the wheelchair and an attendant joystick for someone that's accompanying the driver for a "walk". Seeing as how I only need one joystick on the chair itself, I figured I could keep it there! I don't need to worry about "balancing" the center pin voltage because the joystick will never leave the system, let alone the center. I removed the attendant joystick for my remote Arduino/Xbee set up and soldered a wiring harness in parallel to the primary joystick. In order to move the chair in either direction, put a 100 ohm resistor in series with the positive, and another 100 ohm resistor in series with the negative. I combined the left/right pins with eachother and the forward/backward pins with eachother. then its pretty much just a simple H bridge wiring from here! Apply the 100 ohm resistor-in-series positive to the forward/backward pins and it goes forward, apply the 100 ohm resistor-in-series negative to the forward/backward pins and it goes backward!
Apply the 100 ohm resistor-in-series positive to the left/right pins and it goes left, apply the 100 ohm resistor-in-series negative to the left/right pins and it goes right!
This simple circuit/joystick combo can easily be stashed behind the seat where the victim, I mean player, will not be able to reach it while the game is being played!
Or you could just really freak out Grandpa before the Holiday feasting begins!
Thanks for the awesome Instructable by the way!
dany151 says: Dec 14, 2012. 10:54 AM
if i donot use the xbee ...what are the changes in the code pls???
Xagormax says: Dec 5, 2012. 3:49 PM
On the receiver side, are pins 4,5,6 and 7 the arduino pins that control the relays?
Also, the 2K resistors are connected to + and -. I assume this is the 5v supply on the arduino?
dany151 says: Dec 12, 2012. 9:00 AM
dear Xagormax ...i think those pins are for serial comuncation between the arduino and the xbee .....
for the 2K ..yes
dany151 says: Dec 12, 2012. 5:49 AM
dear amanda
i got arduino-mega2560 without Xbee,and i wanna configure it to accept signal from EOG device (EOG == Joystick)....to which port i connect it? and can i use same code?
i think it need some changes right?
can u help me pls
dany151 says: Nov 2, 2012. 8:37 PM
nice..work
but i couldnt figure out how you connect the 2 joysticks with ardunio!!!
pls add more detials about joystick hack...or send to me at
engmoh81@yahoo.com
Eagerly wait for your answer
amandaghassaei says: Nov 3, 2012. 1:23 PM
The two inputs from each joystick were connected to the arduino like this:
http://www.arduino.cc/en/Tutorial/JoyStick
dany151 says: Nov 4, 2012. 4:27 AM
thnx for reply ...and i wanna ask one more question pls
in my project i will leave the connection of the (vs,Vs/2,GND,Not connect)wires...
cut the (forward,back,right,left)outputs wires
then connect them to the relays as u did in your project ,and the other side to
micro controller .....
and leave the ((forward,back,right,left)) from joystick side not connected
i think this will make the controller work because it must see the joystick
and will not give error in connection...
is it ok?
if im wrong ....pls advice me ....cause i don't hv spare parts...
my regrds....
i will be happy if you add me
engmoh81@yahoo.com
amandaghassaei says: Nov 4, 2012. 2:07 PM
are you hacking a wheelchair or are you just trying to use a joystick with arduino?
dany151 says: Nov 4, 2012. 11:01 PM
I'm hacking the wheelchair i will use Electrooculography (EOG / E.O.G.)
to control the Wheelchair ...so that i must replace the joystick with the signals
coming from eyes Muscle via EOG...
i will use Arduino to translate the signals to the wheelchair
it is clear now?
dany151 says: Nov 5, 2012. 3:55 AM
for the circuit below
http://www.instructables.com/files/deriv/FMY/N3TU/H4ZN57K6/FMYN3TUH4ZN57K6.LARGE.jpg
if the two relays on 2k//2k+1k ===) 2.5 v
if both off 7.1k//7.1k+1k========)1.1v
if one off and other on 7.1k*2k/7.1k+2k=1.56======)2v
the jc2000 output in forward =4 v
in center=2.5v
in backward=1 v
so i couldnt get the 4v for the forward state !!!
is the 2v enugh for that???
randofo (author) says: Nov 5, 2012. 6:45 AM
Both relays should never be on. Both should always be in the off state. 2.5V is neutral.
You are mostly right, but missing an important thing...
If relay 1 on and relay 2 off, it is --- 2K to 7.1K
If relay 1 off and relay 2 on, it is --- 7.1K to 2K
You should be able to get about 4V from this setup.
dany151 says: Nov 5, 2012. 9:53 AM
i didnt understand this
"If relay 1 on and relay 2 off, it is --- 2K to 7.1K
If relay 1 off and relay 2 on, it is --- 7.1K to 2K "
both states give 2 volt at the output ,how can i get 4 V ???
amandaghassaei says: Nov 5, 2012. 10:07 AM
the purpose of the relays is to short circuit the 5.1k resistor it is attached to, effectively removing it from the circuit.
when both relays are off you have:
0V----2k----5.1k--(measure voltage here)--5.1k-----2k-----5V
since there is 7.1k on either side of the point you are measuring, the voltage is half of 5v = 2.5V
if you turn on one relay and keep the other off you have:
0V----2k----relay(0ohms)--(measure voltage here)--5.1k-----2k-----5V
in this configuration there is 2kohms to ground and 7.1kohms to 5V, this causes the voltage at the place of measurement to drop to 2/(2+7.1)*5V =1.1V
if the state of the relays is switched we get:
0V----2k----5.1k--(measure voltage here)--relay(0ohms)-----2k-----5V
now there is 2kohms to 5V and 7.1kohms to ground, this causes the voltage at the place of measurement to drop to 7.1/(2+7.1)*5V = 3.9V
the reason we don't turn both relays on at the same time is because the circuit would look like this:
0V----2k----relay(0ohms)--(measure voltage here)--relay(0ohms)-----2k-----5V
now there is equal resistance on either side of the measure junction, this gives us a voltage of 1/2*5V = 2.5V, same as what we get when both relays are off. this is just redundant, so we don't need it.
hope that's clear!
dany151 says: Nov 5, 2012. 10:30 AM
yup...yup...it is clear thank u very much
now i will applay the 5v dc from microcontroller pins ----to------> this circuit of voltage divider---to------>joystick controller board
for the 4 pins (f/b out1&2,r/l out1&2)
connect the vs/2 as your divider circuit
keep the connection of jc2000 ===>3 wires (vs,gnd,not connect)...
or remove them ????
how to mimic the joystick signals with an Arduino ??
amandaghassaei says: Nov 5, 2012. 10:35 AM
connect pin 3 to ardiuno gnd, leave the rest unconnected
dany151 says: Nov 5, 2012. 11:34 AM
okay...
now i dont hv an experience with Ardunio ..can i use another PIC ,like 8051 microcontroller? isit need ADC ?
in my work it is no need to use xbee radio....
there is any other process in ardunio ??
amandaghassaei says: Nov 5, 2012. 11:43 AM
you need ADC to read the input from the joysticks. But the circuit with the relays, which is hooked up to the wheelchairs, is all digital.
dany151 says: Nov 5, 2012. 11:55 AM
i will take the input signal from EOG ==>ADC==>PIC 8051==>wheelchair joystick controller
or it need to connect the jc2000 joystick?
amandaghassaei says: Nov 5, 2012. 12:01 PM
what is eog?
dany151 says: Nov 5, 2012. 12:10 PM
see this site
http://en.wikipedia.org/wiki/Electrooculography
and tell me if it is need to connect jc2000 joystick or not? cause the wheelchair
joystick controller will not work if joystick not connected ???
is the microcontroller will act as a joystick ? is it need another setting?
amandaghassaei says: Nov 5, 2012. 12:14 PM
the microcontroller acts as the joystick. In this case you will not need to use any joystick, just send data from the EOG to turn off/on the appropriate relays in the circuit above.
dany151 says: Nov 5, 2012. 12:30 PM
that is good ....thank you amanda .... i will make this circuit tommorrow...thnx for your help again ...see u
dany151 says: Nov 14, 2012. 5:19 AM
dear amanda i got this error
A joystick fault is indicated.Make sure that the joystick is in the center position before switching on the control system !!!!
is it voltage drop? or current problem?
amandaghassaei says: Nov 14, 2012. 9:22 AM
when the arduino boots up, make sure all the relays are off, then turn on the wheelchair
dany151 says: Nov 14, 2012. 11:17 AM
i did, but i think that the voltages are unstable at the outputs....maybe it is source voltage problem
amandaghassaei says: Nov 14, 2012. 11:38 AM
the voltage should be 2.5V to all the joystick pins when the relays are off
dany151 says: Nov 18, 2012. 5:13 AM
amanda...the problem is occurred when i connect the pins of control circuit..the voltage drop from 2.5v to 2.23v ....but i solved this problem
by applying 5.5v instead of 5v .....the circuit is worked okay...
an other thing i got ardunio uni ...and i will use it for control....
thnx for your help
1-40 of 48Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
