Pull-Through Braid | HairByRachel
4,855
109
6
Published
Introduction: Pull-Through Braid | HairByRachel
About: This is the place to learn all things hair...DIY, updos, and more:) Follow me on Instagram: @_hairbyrachel_ Subscribe to my YouTube: HairByRachel
This hairstyle is one of my favorites!! It holds really well because of all the elastics and it is also super pretty. Enjoy!
Step 1: Brush Hair
Start with the hair throughly brushed. For some added texture use dry shampoo or curl the hair.
Step 2: Make Small Ponytail at the Top
Take a small section of hair at the top of the hair and tie it off with a clear elastic.
Step 3: Make Another Small Ponytail
Gather two pieces of hair from either side of the head and tie them on the top of the first one. Make sure to smooth the sides.
Step 4: Split the Ponytail
Split the ponytail in two sections. Then grab the middle section and hold it out of the way.
Step 5: Tie the Two Sections Together
Pull in hair from either side of the head and add it in with the two sections from before. Join them all together with a clear elastic.
Step 6: Repeat the Steps From Before
Then take down the top section and split it in two and pin the middle out of the way. Next gather hair from either side of the head and join it with the two sections. Then tie off with a clear elastic. Keep doing this all the way down the head.
Step 7: Pancake the Braid
Once you get a few sections done, pull on the sides to make it seem bigger and thicker.
Step 8: When You Get to the Bottom of the Head
Once you get down to where you can't add hair from the sides any longer, keep doing the same thing but without adding hair.
Step 9: Tie Off With Clear Elastic
Once you get all the way down, finish it off with a clear elastic. Then you are all done!
Step 10: Enjoy!
This style can be worn in so many different ways. You could split the hair in two and do pigtails, you could make it as an accent braid with just a small part of the hair, or you could even do it upside down up into a bun. Have fun recreating!!
    • Spotless Contest
      Spotless Contest
    • Woodworking Contest
      Woodworking Contest
    • Flowers Challenge
      Flowers Challenge
    6 Comments
    I love that look. great for cheerleaders, or dancers too. thank you and your assistant for sharing!
