Introduction: Pumkin Laser Engraving
Picture of Pumkin Laser Engraving
If you have a laser machine i am sure that you already have expermiented a lot of materials, why not pumpkin?
In this tutorial i am going to give you the basis to engrave pumpkin as well as some stencils a pumking stand that you are going to need to engrave your pumpkin
This tutorial is also available in video (sorry for my bad english) if you fancy one :)
https://youtu.be/5sE73TtswRE
Step 1: Watch the Video
If you don't want to , it's fine, i am going to explain everything in the next steps :)
Step 2: Make a Pumpkin Stand
Download the file (i add a .ai and a .pdf but if you need anything just let me know). This pumkin stand is going to make sure your pumkin is not going to move during the engraving process. Because a pumkin is round-shaped it might roll and damage you machine. You don't want that to happend.
It is basicly 3 horizontal board and 2 vertical one cut in 3 mm wood.
Step 3: Choose a Pumpkin and Remove the Inside
Picture of Choose a Pumpkin and Remove the Inside
You are going to choose a pumkin that fits into your machine (mine was 6inches diameter) and that have a flat board.
This flat size will allows you laser to not defocus too much. If you only have perfeclty round shapes pumkin, it is not a big deal, you engraving or cut might be a little bit more bolder than expected.
Remove the inside of your pumkin to make sur there is nothng left in it. (i am not going to make a tutorial on it i am pretty sure you are better than me on this)
Step 4: Make Some Tests
Picture of Make Some Tests
Because every laser machine is different i cannot tell you what are going to be your speed/power settings. The best thing to do is to engrave and cut a little design on your pumpkin.
During every test, note the settings and choose wich one gives you the best results.
Step 5: Time to Have Fun!
Picture of Time to Have Fun!
Now that you know your settings, you can engrave or cut anything you like!
I am giving you a few designs so you can have fin but et me know what you've done!
DIY Hacks and How Tos (author)2016-11-13
This is yet another reason why I really want a laser engraver.
Depending on how much you want to spend in it, Glowforge laser machine is promissing. Althought i am not sure if you can put a pumpkin in it :O
More expensive one you have Epilog in Canada or Trotec ones. Thoses two one have filters and software included.
I would not recomend any chinese because for most of them you haven't got air filter or cooler pr software... but they are pretty cheap
About This Instructable
341views
2favorites
License:
Bio: Canadian agender nerd
More by KitsuneMikan:Laser Cut Coconut ShellWatching the Eclipse Throught Reading Glasses (and Not Burning My Eyes)How to Laser Engrave Candles ?
Add instructable to:
