Pump Action Shotgun
2,634
10
Published
Introduction: Pump Action Shotgun
About: 92% of teens have moved on to rap. If you are part of the 8% that still listen to real music copy and paste this into your sig. Hiya, my official web name is smashpoe, which was a name i invented while i ...
Just my first attempt at a decent shotgun.I might post instructions, but i need to be asked first.
PROS
-high rate of fire for a shotgun,it will fire as fast as you can pump it, because it fires at the end of each pump ( trigger is fake)
-ammo spreads
-comfortrable
CONS
-my first attempt, so,still needs improvement
-only a two shot mag
-bad range(duh, its a shot gun)
-ammo is easily lost
MERRY CHRISTMAS AND HAPPY NEW YEAR
    • Stick It! Contest
      Stick It! Contest
    • Make it Move Contest
    • Pets Challenge
      Pets Challenge
    10 Comments
    Rubiks cube.
    POSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOSTPOST
    Now i know how to make a good true semi auto, by replacing the pump with a trigger on another gun. This is genius.
    nice tech deck in the back ground =D
    is this a mag fed shotgun with a pump?????? OMG :D
     hey im making one can you help?
     post it and everyone will mod it so the trigger is NOT fake, and tell you, so then it will be f ing awsomeness and you will have made a F%&^%& good gun.
    xD
    You should try adding a sear system at the end of the gun. Thus giving it a real trigger.
    I did , but i like the pump firing better.it eliminates the time it takes to pull the trigger, though sometimes i do feel akward firing like that and pull the fake trigger off by accident :)
    it still needs improvement...
