3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Pumpkin Carving Saws
So! You want to kick your pumpkin carving game up a notch and try your hand at one of those fancy complex patterns? Good for you! It's easy! But that's beyond the goal of this Instructable. One thing that you will absolutely need, however, is some precision pumpkin carving saws.
Fortunately, there's no need to go out and buy one of those kitschy pumpkin carving kits - you can make your own saws that perform better and cost less money!
Step 1Tools and Materials
Tools and Materials
All the materials you need to make the saws can be bought at your local hardware store, though you may have everything you need in your workshop already:
3/8" - 7/16" wood dowel (I used poplar because it's inexpensive, but it really doesn't matter)
5" scroll saw blades, 15-20 tpi (teeth per inch), pinned or unpinned ends
JB Weld or some other high-strength epoxy
spray paint (optional)
For the jigs, you'll need some scrap pieces of 2x4 and some wood screws.
The required tools are also pretty basic:
A wood saw (I used a scroll saw)
A drill press (preferred, though you could do it with a hand held drill)
side cutters
pliers
20 comments
Oct 28, 2010. 6:43 AMarpruss says:
I got a pair of 18tpi jigsaw blades at Walmart. They were Black and Decker metal cutting ones with a hole in the shank, for less than $2. They're narrow and nicely rigid. I used a hacksaw to cut a 3/4" deep notch at one end of a piece of 1" square rod. The hacksaw blade is slightly thinner than the jigsaw blade so the fit is snug. I then drilled and countersunk a hole from the side of the handle to engage the hole in the blade. I pushed JB Weld into the notch (with something thin I had lying around), put in the blade, and ran a wood screw through the hole. I didn't like the idea of the blade being held in place just with JB Weld.
Next day I sanded the handle (with a home-made sanding disc in a drill) to bevel the edges and finished the wood with water-diluted water-resistant wood glue (Titebond II; now it's drying--I'll probably put another coat or two on it).
Oct 28, 2010. 8:16 AMarpruss says:
Sorry, no photos of the build process, but the product is here:
http://tinyurl.com/pcutter
Oct 28, 2010. 4:47 PMarpruss says:
Go ahead. That's great!
Mar 26, 2010. 8:20 PMhotstuff666 says:
 omg that witch is awesome how do u do that stuff
Nov 2, 2009. 9:45 PMRamireex says:
I used a cutting disk for my Dremel and sliced down the middle of the dowel about 1/2 to 3/4 of an inch.  Then, I used Gorilla glue, slopped it in the cut and on the blade.  Let it dry for 24 hours and then I used a sanding stone on my dremel to clean up the mess.  None of my "homemade" saws broke and I did a fair number of pumpkins.  I went to Home Depot and got an assortment of jigsaws in different sizes and that did the trick.  I used a small drill bit to make the holes for eyes etc rather than the little plastic drivers that come with the kit.  I then cleaned everything up, oiled the saws and the handles and everything is ready for next year or whenever I decide I want to carve a watermelon, pumpkin etc.  Works great for not very much money and a little time.
Oct 18, 2009. 8:54 AMANTQNUT says:
I love it! my favorite ones are the second picture and the last :D
Oct 14, 2009. 4:22 PMidogis1 says:
I've got a ton of saw from commercial pumpkin carving kits. Are these better?
Oct 8, 2009. 1:18 PMcowscankill says:
Nice pumpkins! Are saws better than knives?
Oct 9, 2009. 1:08 PMcowscankill says:
And what is the difference...? Haha just kidding! Nice job on these, JB Weld is really nice.
Oct 22, 2008. 1:32 PMeffin.fantastic says:
Not as technical as yours, but when I was younger, my dad chopped up a saw blade into ~4 inch lengths and wrapped one end in electrical tape. We were kind of lazy. Things cut like butter, though. I couldn't have done my Zoolander pumpkin without them.
Oct 18, 2008. 8:30 AMdacker says:
This is a great idea for making your own! For years, I've simply taken a coarse-toothed jigsaw blade and clamped it in my Vise-Grips, but this is a better solution than trying to make precision cuts with a two-pound tool.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
347
Author:jeff-o
By day, Jeff is an electronics technologist at a large aeronautics corporation. By night, a mad scientist / hacker / artist / industrial designer wannabe!
