Introduction: Pumpkin Seed Brittle
When I was living in India, my dad would bring peanut and sesame seed brittle for me and my sisters and we used to love them.This is my first attempt to prepare a Brittle and when I tasted this brittle, though extremely tasty, it did not taste anything like what I was used to having. That was because I prepared this brittle using sugar, whereas the ones we get in India are mostly prepared with Jaggery (concentrated cane sugar which comes usually in the form of blocks). Very soon I will be uploading another instructable for a brittle using Jaggery :)
Step 1: Cutting and Cleaning Pumpkin and Pumpkin Seeds
For the preparation of this brittle i have used Sugar pumpkin. Any kind of pumpkin can be used to prepare brittle and this recipe can be followed for making any kind of brittle.
- Wash the pumpkin very well
- Cut the top of the pumpkin which holds the stem, chop the pumpkin in half
- Scoop out all the seeds and membrane using a spoon
- Once the seeds and membrane was removed from the pumpkin, I removed the membrane as much as possible by hand and then put the seeds with the membranes that are stuck to the seeds in a colander and gave it a thorough wash
- Place paper towels on a plate and spread the seeds so the water can evaporate
- I let the seeds dry overnight so i can be sure that the seeds have no moisture left
Step 2: Roasting Pumpkin Seeds
- Take a wide base pan, spread the dried pumpkin seeds on the pan
- On low to medium heat, dry roast the seeds till you get nice aroma and the seeds swell a little. This took 4 - 5 minutes
- Remove the seeds and place on a plate to cool down
Step 3: Ingredients Required to Prepare Pumpkin Seed Brittle
- Pumpkin Seeds - 3/4 up
- Sugar - 1 cup
- Unsalted butter - 2 tbsp
- Baking Soda - 1 tsp
- Water - 1/4 cup
- Salt - 1/4 tsp
- Vanilla Essence - 1 tbsp
Step 4: Steps to Prepare Pumpkin Seed Brittle
- On a cookie sheet, place parchment paper and spray it very evenly with cooking spray
- Take a large heavy pan and put sugar and water and let it come to a complete boil
- Add salt and butter and keep stirring and let it cook till the temperature reaches 300 F
- Remove from flame, add vanilla essence and mix
- Add baking soda and the mixture will bubble up ferociously, keep stirring
- Add the pumpkin seeds and mix well
- Pour the mixture on the cookie tray placed with parchment paper and spread it immediately to get a flat base. To make it super flat, i sprayed another parchment paper with cooking spray and placed this parchment paper on top of the mixture. I then placed a flat based pan on top of the parchment paper and pressed it,to get a flat thin brittle
- Let it cool for 30 minutes
- Remove the parchment paper and break the brittle as needed. Store in airtight container. Done :)
- In case the parchment paper gets stuck to the brittle, which should not happen if the paper was sprayed generously with cooking spray,dip a kitchen towel in hot water and squeeze out the water well and place the towel on the part of the brittle,which is stuck to the parchment paper for 2-3 minutes and the paper will come out easily
Halloween Food Contest
Pumpkin Challenge
