Pumpkin Spice Snickerdoodle Cookies
730
31
Published
Introduction: Pumpkin Spice Snickerdoodle Cookies
Ingredients:
  • 2 sticks of softened butter
  • 1 cup of white sugar
  • 1/2 cup of light brown sugar
  • 2 eggs - warmed to room temperature
  • 1 teaspoon vanilla extract
  • 3 cups all-purpose flour
  • 2 teaspoons baking powder
  • 1 teaspoon pumpkin pie spice
  • 1/4 teaspoon salt
Sugar Coating Ingredients:
  • 3 tablespoons white sugar
  • 3 teaspoons pumpkin pie spice
  • 1/2 teaspoon ground cinnamon
Supplies:
  • Measuring Cup
  • Measuring Spoons (Teaspoon and Tablespoon)
  • Large Mixing Bowl
  • Medium Bowl
  • Small Bowl
  • Hand Mixer (If you have a stand mixer that works too!)
  • Spatula
  • Small Ice Cream Scoop or Two Spoons
  • Non-Stick Baking Sheet (If you do not have a non-stick baking sheet, you can use a regular one just make sure to spray Non-Stick Cooking Spray on it. PAM is a great one!)
  • Wire Rack for Cooling or a plate
  • Tupperware to store cookies
Step 1: Gather All Ingredients and Supplies
I like to gather all ingredients and supplies in an easily accessible place.
Step 2: Preheat Oven Degree to 375 Degrees
This step may be moved if you choose to refrigerate your dough.
Step 3: Combine Ingredients for Sugar Coating in Small Bowl and Set Aside
In this step you will combine the below ingredients and mix well.
Step 4: Combine Dry Ingredients
Combine the below ingredients in a medium mixing bowl and mix well.
1/4 teaspoon salt
Step 5: Mix Well and Set Aside
Step 6: Combine Wet Ingredients in Large Mixing Bowl
Combine the below ingredients in a large mixing bowl. Using the hand mixer, mix until smooth.
Step 7: Mix Until Smooth
Step 8: Add One Egg
If you are using a stand mixer turn the speed to low and add egg.
If you are using a hand mixer it is best to turn the mixer off, add the egg, and then turn the hand mixer on low.
Step 9: Mix Until Egg Is Fully Incorporated
Step 10: Add Last Egg
Step 11: Mix Until Egg Is Fully Incorporated
Step 12: Add Vanilla Extract
Add 1 teaspoon of vanilla extract and mix well.
Step 13: Slowly Add Dry Ingredient Mixture
This works easier by adding the dry ingredients in increments such as 1 cup at a time.
Step 14: Using the Spatula, Scrape the Sides of the Bowl
This is helpful when some of the dry ingredients set on the sides and are not fully incorporated into the mixture.
Step 15: Mix Batter for an Additional Minute
At this point the batter should resemble smooth butter.
Step 16: Scoop Balls of Dough Into Sugar Mixture
Using the ice cream scoop or two spoons drop balls of dough into the sugar mixture. The size of the dough balls should be around 1 inch in diameter. However, it is bakers choice!
Step 17: Roll the Ball of Dough in the Sugar Mixture Bowl Until Completely Covered
If you do not want sticky fingers use the spoon to cover the ball with sugar.
Step 18: Place on Baking the Sheet Roughly 2 Inches Apart
Step 19: Place Baking Sheet in Oven and Set Timer
Baking times is between 10 and 12 minutes but will vary depending on the oven.
Step 20: Remove From Oven and Allow to Cool
I placed mine on a plate to cool but if you have a wire rack it is best to use it.
Step 21: Optional Steps
This recipe makes about 3 dozen cookies. If you do not need that many you can store left over batter in a gallon Ziploc baggy in the freezer or fridge (if you are using it within a few days).
If you want rounder, fluffier cookies place batter in fridge for 30 minutes before coating in sugar. For flatter cookies, coat in sugar and bake immediately.
    • Pets Challenge
      Pets Challenge
    • Stick It! Contest
      Stick It! Contest
    I love these cookies. I need to make these for the Halloween party this year. Thanks for the recipe.
