3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Pumpkin bombs!
Step 9Fill pumpkin
Fill pumpkin
Now, quickly, while the mixture is still hot, in your hands roll the "dough" until it's like a hot dog. Then, rip off about a 1/5th at a time and stick it in the pumpkin. Press around the inside and try to leave a hollow spot in the center, but make sure to use ALL The dough.
You should see something happen... (ignore with plastic pumpkin)
Water should start seeping out of the inside of the pumpkin... kinda like if you were baking it... this is BAD, before you fill the pumpkin, I'd suggest drilling a couple holes in the base to let this water out. You may want have the holes drilled from the next step done first!
The water is our enemy. basically, just let it drain and dry as much as you can with the paper towels. Plan to use the pumpkins TONIGHT. Pumpkins go bad quickly anyways, once you make the first incision, generally they have two days left before they look bad.
I used a spoonful of corn starch to suck up the water, and it seemed to help a good deal, if there's a better way, LET ME KNOW, but the cornstarch coated interior worked pretty good.
Any way you look at it, make sure to have some holes drilled in the base before you start filling the pumpkin.
2 comments
Nov 16, 2010. 7:40 PMspenfisher12 says:
i like jamming m 80s in them i will stick to that
Jul 12, 2008. 10:54 PMGordieGii says:
I would coat the inside with wax. When I used to make this stuff I didn't put it in a pumpkin, just formed to a handy shape. (think Hersheys Kiss) If it sat around for a couple days it would suck the moisture out of the air and turn into taffy. (and hard to light) Gordie
Sep 11, 2008. 10:21 AMwiebevandomburg.hotmail.com says:
yep m i had the same problem with potassium chlorate and it got wet but only when the sugar was added
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
54
Author:thecheatscalc
