The main property of the pure tone radio is to be as sustainable as possible. The reason for the large body size is to allow a low powered speaker to be amplified without extra electrical power. The body acts as an acoustical amplifier and because of this the sound is amplified to great effect.
Another key factor to this design is the hand powered dynamo that is used to charge the battery within the device. This feature works much like the one that can be found in wind up torches. The components and materials used to design and manufacture this device will be recycled and mainly sourced from a sustainable
Remove these ads by
Signing UpStep 1Manufacture Overview
Tools Needed:
4 x Small Hand Clamps
1 x Small Panel Pin Hammer
1 x Chisel
1 x Roll of Duct Tape
1 x Bottle of PVC Glue
1 x Hand Drill
1 x Coping saw
1 x Epoxy Resin
1 x Epoxy Hardener
Selection of Wood Files
Selection of Drill Bits
80 grade Sandpaper
230 grade Sandpaper
Access to a Pillar Drill
Access to a Ban Saw
Access to an Industrial Sander
Access to a Hand Sander
Materials Needed:
200 x 300 x 5mm Pine Plywood x 2
750 x 180 x 1.5mm Pine Plywood x 1
600 x 30 x 20mm Pine x 1
110 x 90 x 5mm Pine Plywood x 1
*Plus Other Sourced Components
Any one have some tips for beginners?
Although you still have the old radio case as waste but perhaps the plastic will recycle.
As an art project it's great.
A great many radios of the first half of the twentieth century were made in cabinets of this type of construction. Things of beauty, like fine furniture some of them. Then came Bakalite. *aack* (personal opinion)
Add some detail accents and a fabric grille and you have a 20's Deco style radio (without the vacuum tubes).
Replace the 1/2" to 1-1/2" speaker with a little larger 2"-4" you scrounged from something and get a little fuller warmer tone.
Or even take the transducer out of one of those sound-playing greeting cards and mount it on the wood into a speaker itself instead of just a resonator.
Hardly earth friendly, as I understand the definition anyway.
