3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Awesome Push Button Ignition
Step 2Open Up the Dash
Open Up the Dash
Here you will need to get inside your dashboard to where your ignition harness is. This is near the keyhole. Once you get to this bundle of wires you will need to cut the Ignition Wire and the Starter wire, so also disconnect the battery first. You will have to find a wiring diagram for your car to know what wires do what. I can tell you that for Hondas the Ignition wire is black and yellow, and the Starter wire is black and white.
Cut these wires and strip the end enough that you can solder it or splice it well.
Just a caution, this step, more than any others so far, has a potential for really messing up your car. as long as you cut the wires such that you can splice or solder them back together you should be ok, but be aware that cutting wires to your ignition could become a problem.
3 comments
Oct 4, 2011. 3:24 PMhondacivic158 says:
so do i connect the starter wire directly to one switch and the ignition to the other switch? then from the switch to the relay
Apr 29, 2009. 8:58 PMsuperdean says:
do i need to use a One Single Pole Double Throw Relay... wat does it do
Mar 27, 2011. 1:28 PMjpayton says:
It seperates the small switched for the possable 20amps the ignition can draw.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
24
Author:HAL 9000
I'm working towards a Bachelors Degree in Mechanical Engineering at Oregon State University.
