Introduction: Push Button With NodeMCU
Hello Makers,
In this instructable we will see the easiest way to connect the Push Button to NodeMCU.
The example turns on an LED when you press the button.
The pushbutton is a electronic component that connects two points in a circuit when you press it.
We use these little buttons on everything! These Miniature Single Pole Single Throw (SPST) switches are breadboard friendly. Perfect as a tactile reset switch. These buttons are rated up to 50mA.
Typical Push Button Switches Applications : Calculators, push-button telephones, various other mechanical and electronic devices, home and commercial.
Step 1: Components Needed
List of parts required for this instructable :
Hardware Required
  • NodeMCU
  • Push Button
  • 10K ohm resistor
  • Bread board
  • Micro USB cable
  • Connecting Wires
Software Required
  • Arduino IDE (with ESP8266 Library installed)
Step 2: How It Work's
When the pushbutton is open (unpressed) there is no connection between the two legs of the pushbutton, so the pin is connected to 3.3v (through the pull-up resistor) and we read a HIGH.
When the button is closed (pressed), it makes a connection between its two legs, connecting the pin to ground, so that we read a LOW. (The pin is still connected to 5 volts, but the resistor in-between them means that the pin is "closer" to ground)
So, Let's get started with connecting PushButton to NodeMCU.
Step 3: Circuit Connections
The first pin goes from one leg of the pushbutton through a pull-up resistor (here 10K Ohms) to the 5v supply.
The second pin goes from the corresponding leg of the pushbutton to Ground pin.
The third pin connects to a Digital I/O pin (here pin D0) which reads the button's state.
LED Anode is connected to Digital I/O pin (here pin D1) and Cathode to GND pin.
Step 4: CODE
int led = 5;     // LED pin
int button = 16; // push button is connected
int temp = 0; 	 // temporary variable for reading the button pin status</p>
void setup() {
  pinMode(led, OUTPUT);   // declare LED as output
  pinMode(button, INPUT); // declare push button as input
void loop(){
  temp = digitalRead(button);  // read input value
  	if (temp == HIGH)     // check if the input is HIGH (button released
	  digitalWrite(led, HIGH);  // turn LED ON
	else {
	  digitalWrite(led, LOW);  // turn LED OFF
Download the "Button_NodeMCU.ino" file and open it up in the Arduino IDE.
Then Create a new sketch and paste the code below in the Arduino IDE and hit Upload. You can tinker with it if you like based on the application, or just use it as it is.
Step 5: Output
That's all Makers.
You have successfully completed another instructable, It takes pretty less time to create this instructable, and its fun too.
About This Instructable
62views
4favorites
License:
Bio: Work until you no longer have to introduce yourself.
More by TheCircuit:Control Servo Using LDR With NodeMCUAuto-LED Using LDR With NodeMCUNodeMCU With LDR
Add instructable to:
