Push-Pin Pumpkin
Introduction: Push-Pin Pumpkin
This is a super-simple craft for all ages (parent supervision recommended for young children) that leaves you with a quaint little pumpkin decoration!
Step 1: Materials
You will need:
-12 inches (30 cm) of 3/8"(1cm) width ribbon
-1 push-pin
-1 pair of scissors (not pictured)
-(optional) craft paste/hot glue/etc. and a small pebble
Feel free to get creative with the colors and sizes of your ribbon! You can also use wired ribbon to make a larger pumpkin that can you can shape!
Step 2: Cut the Ribbon
Cut the ribbon into three 4"-long strips of ribbon.
Step 3: Make Loops
Carefully pin the ribbon onto the push-pin in loops, one at a time.
Step 4: Finishing
Arrange the ribbon so they are evenly spread. You're done!
You may want to put a dab of glue between the bottoms of each ribbon to hold it in place, which will also help add weight to keep small pumpkins balanced. You can also glue a small pebble on the bottom or inside the pumpkin to keep it from being top-heavy.
Safety tip: To avoid accidental pricks from the push-pin, you can us a hot-glue gun and put a dab of glue on the pin's tip to shield from the sharp edge.
Next time, try making a pumpkin decoration with more than three loops, or with larger and wider ribbon!
    • Paper Contest 2018
      Paper Contest 2018
    • Trash to Treasure
      Trash to Treasure
    • Pocket-Sized Contest
    Sucu a simple and clever idea :))
    Yes, and you can really get creative with variations! :]
