We've all been there. Invert. Jiggle. Shake. Slap. Nothing. When a Furby goes comatose, there seems to be no hope of getting him or her awakened. This Instructable will show the steps to take Furby apart and push start him back to life. This has worked on my own two so far and will likely work for yours, as this seems to be a common problem. After a lot of experimenting and battery changes, I determined the cause for this state is improper parking of the motor that drives furby's mechanisms. Just like a fine industrial robot, Furby cannot start his program properly unless he is parked in the home position. Read on and be sure to look at the photos, and hopefully bring your old friend back to life!
To do this instructable you will need:
A comatose furby (won't wake up or reset)
A hobby knife
A small phillips screwdriver
A small flat screwdriver
A hot glue gun and glue stick
A sewing needle
Thread to match the color of the back of furbys ears.
Scissors
4 Fresh AA batteries
Step 1Check Furby's Vitals.
First before continuing on, if you haven't done so insert fresh new batteries into Furby, turn him upside down and press the little reset button on the bottom. If this doesn't wake him, remove the batteries, and secure the battery door so it's not in your way. Now check the base of the furby and note it's position. If properly parked, furby should be leaning forward as to sleep. If the base isn't extended from Furby's bottom, this Instructable is for you. Toh Loh is a Rainbow Furby. After an extended period of storage, he has entered the comatose state. Note his position sitting flat on the table. Also note the dazed and confused look on his face. (Yes, I'm looking for his other eyelash).
I guess it's possible I need better batteries?
Definitely saves the risk of opening it up
i am so excited.... and yet sad. bc i had a furby i loved who went coma and i got ride of him.
glad i could fix this one for my bff's bday :-)
It broke my heart when he stopped working ):
Following these directions and he's back in working order. What I'll do with it, I have no idea, haha... but he works!
Mine is slightly different in that the face plate had 2 screws and a clip holding it in place.... so no need for any glue around the face but the fur around ear openings was glued down instead of clipped. Other than that most of the same directions worked.
(Thanks a lot !)
Ça a marché !
(It worked !)
Merci d'avoir mis cette solution en ligne !
(Thank you for putting this how-to online !)
Thank you.
Sincerely.
