3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Push-Start a Comatose Furby
We've all been there. Invert. Jiggle. Shake. Slap. Nothing. When a Furby goes comatose, there seems to be no hope of getting him or her awakened. This Instructable will show the steps to take Furby apart and push start him back to life. This has worked on my own two so far and will likely work for yours, as this seems to be a common problem. After a lot of experimenting and battery changes, I determined the cause for this state is improper parking of the motor that drives furby's mechanisms. Just like a fine industrial robot, Furby cannot start his program properly unless he is parked in the home position. Read on and be sure to look at the photos, and hopefully bring your old friend back to life!
To do this instructable you will need:
A comatose furby (won't wake up or reset)
A hobby knife
A small phillips screwdriver
A small flat screwdriver
A hot glue gun and glue stick
A sewing needle
Thread to match the color of the back of furbys ears.
Scissors
4 Fresh AA batteries
Step 1Check Furby's Vitals.
Check Furby\
First before continuing on, if you haven't done so insert fresh new batteries into Furby, turn him upside down and press the little reset button on the bottom. If this doesn't wake him, remove the batteries, and secure the battery door so it's not in your way. Now check the base of the furby and note it's position. If properly parked, furby should be leaning forward as to sleep. If the base isn't extended from Furby's bottom, this Instructable is for you. Toh Loh is a Rainbow Furby. After an extended period of storage, he has entered the comatose state. Note his position sitting flat on the table. Also note the dazed and confused look on his face. (Yes, I'm looking for his other eyelash).
62 comments
1-40 of 62next »
Mar 20, 2012. 8:05 PMn0saj2600 says:
AMAZING! I'm just getting into Circuit Bending & Furbys. I ordered a bunch from eBay, some working and some "broken." I just opened one of the broken ones and had it working within a few minutes of reading this tutorial. Thank you so much!!!
Oct 12, 2011. 2:49 PMtheantiyou says:
We have 3 unopened Furby's in our store with this same problem. The Halloween, Christmas, and Valentines Day. All we had to do was replace the batteries and press the bottom/ rocking stand in and out. This with rotate the cam slowly, you will see its eyes close slowly as you feel the stand starting to get stiff like it should be in sleep mode.
Definitely saves the risk of opening it up
Feb 25, 2012. 6:49 AMfurbyqueen says:
Hey this worked for me too. I got a lovely limited edition Spring Furby on ebay that was comatose when it arrived. But I just pumped the bottom stand with the batteries in like you said and it woke up after a couple of minutes. So pleased!
Feb 23, 2012. 2:56 PMBijoou says:
I have 3 troubled Furbeys including one donated to an Episcopalian Church run Thrift Shop away because he/she/it was very fouled mouthed. I say Sir, do you make house calls?
Jan 31, 2012. 8:46 PMsarlee says:
maybe im not strong enough, but how did you push the zip tie without any damage? i have been trying to get past that point but its prooving to be impossible. at least for me. is it suppose to be this hard or am i doing something wrong?
Jan 14, 2012. 5:06 PMkvpla says:
You Rock!! The little fella WORKS!! :-))) I may regret it but 6 yr old got this for Christmas, brother had it sitting wrapped in package for years, now she can experience a cool toy from the past!!
Dec 20, 2011. 2:52 PMPankake says:
Question, I get movement from Furby but no sound. It seems it will respond to sound, light, and being turned over. Any suggestions?
Nov 13, 2011. 10:45 PMinikki says:
I know this is about a year old, but I just recently aquired a furby this guy had, and found this. I was taking off it's skin when it decided to wake up before me not doing anything else, but he'd only go back to sleep. I let him sleep for awhile(a couple hours) and then tried to wake him back up again. I tried the tongue and jiggling thing but he still went to bed.
I guess it's possible I need better batteries?
Oct 15, 2011. 4:56 AMsny1 says:
Hi, I just bought a brand new unopened Bear Furby off of E-Bay and had the same problem. I was lucky to find your website with instructions and now my Furby is alive and very active. Thanks so much for posting this!! xx
Jan 9, 2010. 10:33 AMthegreenfurby says:
I accidentaly broke the zip tie and I can't get my furby back togather, and I can't get him to work either.
Sep 29, 2011. 6:58 PMdclark21 says:
Well, for the zip tie (which I accidently broke myself) I just use thread to substitute for the tie. About your other problem. dunno. I was just following the directions to repair my own Furby.
Sep 29, 2011. 5:53 PMdclark21 says:
Fortunately for me, I had a Coma Furby that used screws to keep the faceplate on instead of glue. I do not own a glue gun. I was happy.
Sep 29, 2011. 5:41 PMdclark21 says:
Thank you! You're instructions saved Meemee, my Christmas Furby! Now my Halloween Furby, Tohloo, won't be lonely anymore. (They just sang themselves to sleep... lol)
Aug 31, 2011. 4:28 PMPlastic Panda says:
I acquired an adorable orange "Halloween Furby" in an unopened box only to find that she also was comatose. However she emerged from surgery bright and cheery! Thank you for the instructable, without which there would be no Maylah. :)
Aug 6, 2011. 1:49 PMtcateon says:
OMG@! It worked!
i am so excited.... and yet sad. bc i had a furby i loved who went coma and i got ride of him.
glad i could fix this one for my bff's bday :-)
Jul 9, 2011. 8:35 PMcfletcher2 says:
Started mine.. Worked for a while, went to sleep.. Back in a coma.. So Im trying again. THIS DAMN FURBY WILL NOT WIN!!!
Jun 29, 2011. 12:29 PMabriggs451 says:
my daughter is seven and didnt know what a furby was so i pulled 2 new still in the box out of my closet put in batteries and nothing!! I did the surgery to 1 of them and it was a success! Now my daughter can enjoy them just like i did when they came out! Off to do the other now so they can chit chat!
Jun 3, 2011. 11:04 PMjcrowe3 says:
I got my brand new furby off of Ebay and the same thing happened to me. I put in the batteries and nothing happened. I decided to try this and it worked! Thank you so much for posting this, you're awesome! :)
May 30, 2011. 7:57 AMksharp-brown says:
Hi! Thanks for these instructions, they workd perfectly, but when my furby turned on, only his mechanical side worked.. he isnt making any sound.. any suggestions??
May 26, 2011. 12:04 AMnessafly83 says:
I am so greatful i found this!!! I honestly thought I probably couldnt figure it out but it went so smoothly and my furby started right up with a yawn and a cockadoodle doo! Now my kid brother can have all the fun i had with this toy!Thanks amillion!
May 18, 2011. 3:14 PMrmaloney says:
Hello there, Ive tried this on my grey furby. Once I have the cam in the down posistion, I don't hear the motor pulsating as I turn, so it's not working :( . The batteries are 1.5 v...Any suggestions or other things to look for?
May 17, 2011. 11:52 AMmacatraca says:
Worked succesfully in my 1st gen Spanish furby. Thanks!!!
Jan 9, 2011. 9:14 PMxgothxgirlx says:
I want to try this but i'm quite nervous about breaking the zip tie, because my furby tulu was a limited edition 1999 christmas furby.
It broke my heart when he stopped working ):
May 3, 2011. 9:09 PMwmire says:
You could replace the zip tie if it does break. They are not expensive and you can get them at home depot. You'll have to open the end of the sleeve it sits in, and then stitch it back together by hand, but it isn't hard and won't show... I'm fairly certain this is what they did when they put them together in the factory. When I opened mine, her' s shattered, so i ran a piece of white cotton yarn through the sleeve, tied it tight and trimmed the ends. Good as new!
Apr 29, 2011. 9:26 PMjallen2 says:
Worked great! Other than he sneezes a lot. My Furby also had screws holding his faceplate on(generation 2 giraffe) . So glad that I didn't have to dispose of him. Thanks for the great guide!
Apr 18, 2011. 11:41 AMskiel says:
thank you for this tutorial i fix my girlfriend furby¡¡¡¡¡¡¡¡¡ the speaker was dead :D i don't spend nothing....:D
Apr 8, 2011. 10:16 PMtoadworshipper says:
Thanks so much for posting this I just used it to resurect a NIB Ebay 1999 toy; my first Furbies. Pretty cool I feel like Dr. Frankenstein. If these instructions weren't here & clear this delightfully disgusting toy would probably be needlessly orphaned on the Island of Misfit Toys . . . .
Mar 26, 2011. 4:51 PMvlawton says:
Thanks a bunch! I was cleaning my basement and came across my old furby. He was doa.
Following these directions and he's back in working order. What I'll do with it, I have no idea, haha... but he works!
Mine is slightly different in that the face plate had 2 screws and a clip holding it in place.... so no need for any glue around the face but the fur around ear openings was glued down instead of clipped. Other than that most of the same directions worked.
Feb 21, 2011. 1:10 PMjudehargreaves says:
Absolutely brilliant guidance. I am not technically minded at all but I have now bought my Furby out of a coma after 12 years in its box! Thank you!
Feb 21, 2011. 4:01 AMjudehargreaves says:
Hi, I have just found my furby in its box where its been for the last 10 years at least. I have put fresh batteries in but nothing is happening. I've read your tutorial and am tempted to have a go but wonder if it is worth it as the furby is in the tilted forward position. Do u think its worth the effort if this might not be the same problem? Thanks
Feb 6, 2011. 12:00 PMengarga says:
thanks!! my spanish furby is alive!!
Jan 27, 2011. 5:18 PMsnowtime500 says:
Thank you! Perfect directions!
Dec 1, 2010. 10:07 PMcinnyswirls says:
Worked flawlessly on a new furby bought from eBay. Thank you so much for posting this tutorial!
Jul 27, 2010. 10:54 AMchelseatheheart says:
I bought a Furby from Goodwill today and he wasn't working...i did your tutorial up to the part where you turn the gears and it's not working. I've been turning it to the right for over an hour. :/ Any help
Jul 27, 2010. 12:18 AMchelseatheheart says:
I bought a Furby from Goodwill today and he wasn't working...i did your tutorial up to the part where you turn the gears and it's not working. I've been turning it to the right for over an hour. :/ Any help?
1-40 of 62next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
9
Author:lambsb
