Step 12Sew On the Ears
iImage Information
Push the ears on until they touch the head at the ear slot. Now thread your sewing needle using the ear colored thread and pull about 8 inches through the eye. Cut the thread 16 inches long and tie a knot in the end securing both strands together. Starting from the back of the ear, push the needle through the fabric and feel around until you get it through the little hole in the ear skeleton. You can feel if your in the hole by trying to move the needle around. Pull the thread all the way through until the knot stops at the back of the ear. Now insert the needle back into the front of the ear, and pass it through above the hole, towards the head to hook the thread behind the arrow shape hook on the ear skeleton. Pull the thread taught. Now insert the needle back where you started on the back of the ear, back through the hole in the skeleton. Keep looping the thread in this manner until enough thread is looped to securely hold the ears on and resemble the original stitching. Try to keep the thread straight and neat, and use the same holes in the fabric each time to create a factory appearance. Once the loop is strong enough, stop stitching with the needle on the back side of the ear. Push the needle through the stitch on the back of the ear and back through the loop to make a knot, then using scissors, cut the excess thread from the back of the ear. Be careful not to cut the knot! Repeat with the other ear, making sure both ears are even and the stitching looks the same.
