Put UV tatoo on your wall by joudas
Featured
video Put UV tatoo on your wall
I got UV paint additive from a friend. Sorry that I can't tell you where to get it or a brand or anythink, because I don't know (maybe someone in discusion can add that?). I just mix it 1:20 with basic white color, select pattern I wanted to use. Printed it in 1:10 scale (1mm on the print = 1cm on the wall) and transfer it to the wall using masking tape (2x50m). Dimension of the wall are 3,6m x 2,6m, UV light is 25W Omnilux UV light bulb.
generator says: Sep 27, 2011. 9:55 PM
highlighters are uv responsive
scoochmaroo says: Sep 27, 2011. 10:40 AM
Awesome. I'd love to know more about how you transferred the design onto the wall. It looks like you just did it freehand, but it also looks so perfect!
joudas (author) says: Sep 27, 2011. 11:19 AM
as you can see in video I used 3 vertical and 3 horizontal guiding lines, same on the paper, after that I just measure position of 3 tips of the triangle and the same on the wall (e.g. 1st tip is 4cm to the left and 4cm up from the center on the paper = 40cm left and 40cm up from center on the wall = you have 1st point, I mark the point using pencil, then you just conect 3 points with masking tape = done :)
4 * 11triangles * 3points = 132points
first 11 triangles took me about 40min, second batch was done in 30.
Then I had to paint it and remove the tape because it was really full of tape in the middle
luc.dof1 says: Sep 27, 2011. 10:06 AM
Beautiful, well done!
Bongmaster says: Sep 26, 2011. 2:38 PM
pretty neat :)
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
