Put Your Batteries on the Outside
Introduction: Put Your Batteries on the Outside
Some devices are a pain to open up and change the batteries.  If the device is not often used the batteries are usually dead when you want to use it.  What a pain.
Easy fix:  put the battery on the outside.  Also easy to use a plug in adapter so no battery is even necessary.  This method has minimal impact on the device, so it is easy to go back to keeping the battery on the inside.
The example here is a digital multimeter with inconvenient access to its battery.
Step 1: Tools and Material
  • The device to modify, here a digital multimeter.
  • Battery Clip - hard to find, I found mine at Lowes in the hardware "Hard to Find" section
  • Dead 9 volt batteries for salvage
  • Wire
  • Drill
  • Soldering Iron.
  • Misc; small tools
Step 2: Battery Connector
We will salvage the clips from a couple of batteries to make a cable with clips on both ends.  One clip goes to the clip in the meter, the other to the battery.  If you search instructables for "9 volt battery clip" you will find that the salvage is a frequent topic on instructables.  One example is: How to make a 9 volt connector by zelda81596  https://www.instructables.com/id/how-to-make-a-9-volt-connector/
For our use we will put 2 clips on the wire.  One detail is that the positive wire is connect to diferent sides of the clip at the two ends.  This is to make sure the correct polarity is delivered to the meter.  Note that the connector needs to be assembled after threading it through the case ( see next step )  Insulate the clip, I used tape, other methods including hot glue also work.
Step 3: Modify the Meter
Open the case to get at the battery.  In my case this involved 3 screws.  I drilled a hole over the battery compartment, threaded the wire through and added the clips.  Connect a new battery to the outside clip, and then check that the polarity of the inside clip is correct for the meter.  If everything is fine, disconnect the battery.  The battery holder needs to be mounted to the case.  I used the holder shown in tools and materials, but you could mount it other ways, perhaps using velcro on the case and battery.  I chose to use the battery holder and it was handy to mount this using one of the three screws holding the case together.  I had to get a new screw just a bit longer than the original.
Close up the case.  Connect up the battery.  Welcome to the age of easy battery change.
Step 4: Use a Power Supply
If you have or make a 9 volt power supply you can make another 9 volt clip and connect it to the supply and use it instead of a battery.  A couple of notes here:
  • Make sure the supply is really 9 volts DC do not trust the marking on the supply.
  • Be careful to observe the correct polarity.
  • Typically the battery negative is not the common terminal on the meter.  In this case you should not use a common ground for the meter supply with the rest of you equipment, Let the supply "float".
    • Science of Cooking
      Science of Cooking
    • Trash to Treasure
      Trash to Treasure
    • Paper Contest 2018
      Paper Contest 2018
    You've breached the double insulated body so I wouldn't test any high voltages!
    most basic multi meters are rated at 600 v maximum
    This is an excellent point. Most of my work is under 30 v, but not always. Thanks.
    A better way of doing this would be to simplify the opening of the battery compartment....
    Closer observation shows that the battery compartment is reached only by taking the entire back off the meter. You could cut a hole into the battery compartment, Not so easy to reverse. Different methods have their own advantages and disadvantages. Better/worse usually can only be judged withing an entire framework of goals and costs.
    This seems like an awful lot of work just to keep from having to unscrew the back of a multimeter. Not to mention multimeters use very little power, so changing batteries happens maybe once a year. This probably isn't the best example.
    Actually not much effort. We should all decide what is worth doing. Much more effort went into writing it up ans sharing. There are meters ( and other devices ) both easier and harder to open.
