Your CG, as a complex electronic device, has a built-in diagnostic mode that you, as a CG owner, can use to help you get it working again. Now those nice folks at CatGenie don't want this to be common knowledge for the very legitimate reason that you can damage your CG and quite possibly your whole house if you screw this up. Leave the motor running or the fan blowing and you could burn the dumb thing up - or burn your house down. Leave the water running and you'll have one helluva mess. So be careful with this information.
That said, let me say this: I am giving you the codes and the knowledge to use them - but you do so at your own risk. I have had my CG's long enough that they are out of warranty, and it appears that CatGenie is really not that enthused about supporting them - they'd rather upgrade ya to the fancy new 120. Fine - a company's gotta make money; on the other hand, if they're not going to support us, I figger we need all the information we can get to support ourselves. Damn the man!!! :-)
Remove these ads by
Signing UpStep 1Doing Your Diagnostic Thang
- Unplug the CG.
- Push and hold both buttons on the control panel.
- Plug the unit back in, holding both buttons.
- Hold both buttons about six seconds - until you see the lights on the control panel finish the normal power up sequence that you always get when you plug it in AND it starts a new sequence of flashing and beeping. NOW you can let go of the buttons.
- If you did it right, the "4" will light up, go out and then the "1" will light up. All other lights will be off.
- Congratulations, you're ready to get your diagnostic on!
Press and release the Auto Setup ("AS" from now on) button. This will advance to the next test. Test numbers are designated by the 1 - 4 lights across the top. More than one light might be on at a time.
To Start/Stop a Test:
Press and release the Start Cycle/Pause ("SCP" henceforth) button. Pressing once will start a test. You have to press it again to stop the test or it'll run until it burns out the motor or floods the room and shorts out or until some sort of disaster occurs, so PAY ATTENTION!
To Exit Diagnostic Mode:
Simply unplug the unit and plug it back in without holding the buttons - or pick up the processor and reseat it on the unit.
About The Tests:
Tests are referred to by the lights that illuminate (1 thru 4) for each test. Press the AS button until the right lights are lit up.
At this point, I am manually running all of the cycles and adding solution from a cartridge that I withdraw with a syringe. Takes FOREVER but gets the job done.
Any ideas?
Check your manual on instructions on how to clean the sensor. It's fairly easy, especially if you have the updated hopper. If you don't, you can order it from Catgenie.
