3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Put an LCD in your Poker Table
Step 17Place LCD in it's rightful home
Place LCD in it\
Now, finally, you can flip the table back over, put the rail on, and lay the LCD and smoked glass in place.
Using the wing nuts below the shelf, adjust the height of the four corners to get just the right fit. Start by placing the LCD onto the shelf, and moving the shelf up to the point where the glass will sit above the surface.
Then, slowly lower each corner until the glass is just right. You want to adjust all four corners at the same time, working your way around as you go. Go slowly and evenly, and you can get a perfect fit.
Remember, you want both the glass and the speedcloth to be even, or cards will jump when crossing between the two.
You can see in the second image here, when set up correctly, cards will slip across both glass and table without an issue.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:je1330
