3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Put your R/C car under computer control
Step 7Connect your board to the transmitter
OK, so now, solder the 1K resistors onto the base leads of each transistor on you transmitter. Now, solder wires from each of the resistors to the PB0-PB5 lines of your microcontroller. (Remember that my transmitter had 6 buttons, so if yours doesn't have that many, don't feel bad.)
Connect the positive battery(probably red) wire from the transmitter to the 7805's VCC pin on your board. Connect the ground wire to ground on your board.
And now's probably a good time to wire up the serial DB-9 connector to your board. Connect the PC_TX line to pin 2 of the DB9 connector, the PC_RX line to pin3, and the GND line to pin 5. There are tiny little numbers on the solder side of the DB-9 connector that should give you an idea of what I'm talking about. If you don't see them, look up DB-9 pinout in google, and that oughta help
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
65
Author:prank
here: http://www.artiswrong.com But really, I'm just this guy. For up-to-the-minute, action-packed updates on my life (and occasional drawings of tapeworms getting it on), check out my blog here: ht...
more »
