Putting Together Your Stars and Stripes Necklace
99
4
Posted
Introduction: Putting Together Your Stars and Stripes Necklace
A quick DIY on how to put a chain on your Stars and Stripes focal piece. No glue and no wait time required!
*Assemble with friends as an interactive party favor!
To buy the focal piece, go here: http://shpws.me/I3bc
Step 1: Tools
To continue, you'll need:
1.) Jump Rings - Circular hoops used to connect pieces to chains and other fittings. Can be purchased from local craft store or online.
2.) Chain - can be substituted with a cord, string, strap, etc. In this case, I used the pliers to unlink the chain, separating it into two pieces. *If using cord, string, strap, etc., the focal piece can simply be tied on, rendering the jump rings unnecessary.
3.) Clasp - if the chain doesn't already come with it. Can be used with cord, strings, straps, etc.
4.) Pliers - (or jewelry pliers) can be purchased at most local retailers or online. *Not needed if jump rings or linked chains not being used.
Step 2: Open the Jump Rings
Use the pliers to pry the jump rings open.
To do this, I stuck the nose of the pliers into the jump ring and pulled the pliers open.
Step 3: Link
1.) Hook the foremost chain link around the open jump ring.
2.) Do the same with the focal piece.
Step 4: Close Tight
With everything linked, use the pliers to squeeze the jump ring closed.
Make sure that the chain links can't slip out through a gap in the jump ring. *You may need to manipulate the jump ring so that the ends overlap slightly to keep things from falling apart.
    • Trash to Treasure
      Trash to Treasure
    • Microcontroller Contest
    • Spotless Contest
      Spotless Contest
