Introduction: Puzzle Cube
A small cube made of wood. It is made up of 6 smaller parts. Try putting it together.
Step 1: First Piece
This is one of the wooden pieces. For best results, one should use smaller wooden cubes and attach them as seen is the picture.
First, you should glue together two cubes.
Then, take another two cubes and glue those together.
Finally, take your two pairs of cubes and attach them as seen in the picture.
Materials-(4 small wooden cubes, glue).
Step 2: Second Piece
For the second piece, you will need 5 small wooden cubes and some more glue.
First, you should glue together 3 pieces in a row. []-[]-[].
Then, you should take 2 pieces and glue those together.
Then, you should glue them together to look like an L from the top and side.
Materials-(5 small wooden cube, glue)
Step 3: Third Piece
For this piece, you will need another 5 cubes.
First, you should glue together 3 cubes in a row. []-[]-[]
Then, you should glue 2 pieces together.
Finally, you should glue to pieces to make the final piece look like a right angle with two cubes extending from the vertex.
Materials-(5 small wooden cubes, glue)
Step 4: Forth Piece
For this piece, you will need 4 cubes.
First, you should takes three cubes and glue them together in a row. []-[]-[]
Then, you should glue one cube to the middle of the row.
The final piece should look like a tetris t-block
Step 5: Fifth Piece
For this piece, you will need 5 cubes.
Then, you should take 2 more cubes and attach them to the piece you built, making a U shape.
Step 6: Final Piece
First, you should put 3 cubes together in a row. []-[]-[]
Then, you should attach one cube to the side of one of the end cubes.
The resulting piece should look like an L.
Step 7: Puzzle
Try putting together the six pieces to make the cube. There are multiple solutions, but it should still be a puzzling task.
