Wooden Puzzle Modular Electronics Prototyping Board
Published
Introduction: Wooden Puzzle Modular Electronics Prototyping Board
About: Software Developper by day, maker and learner by night/weekends ;)
I didn't have enough space on the prototyping board that came with my Arduino starter kit... so I decided to make a new one. It's modular, so I don't have to use all the parts all the time, it has a module for the Arduino Uno and one for a battery holder or something else. Those two could be replaced by a module with an Arduino Mega, an Intel Edison, a Raspberry Pi or anything else. It also has 2 modules with connectors and breadboards.
So this is how I built it... well some parts were not filmed and I didn't take many photos... I somehow forgot because I was filming some parts probably. But you can see most of the build in the video :)
If you like my build, please like the video on YouTube and subscribe, it would be nice :)
Step 1: The Plan
So I had a plan in mind... have some modules and put the together like a puzzle... this is what it looked like.
Step 2: The Equipment
Step 3: The Equipment Part 2
Step 4: The Components
  • MDF (Medium-density fibreboard)
  • An Arduino Uno
  • Some connectors
  • Breadboards
  • A battery holder or anything else you want to put in the other module
Step 5: Cut the Pieces
I used a scroll saw to cut the pieces, I know it's not the best to cut straight, but I live in an apartment and space is limited... I don't have lots of tools, after measuring them... measure twice, cut once. Then I sanded the pieces so they would be as close to perfect as possible.
Step 6: Sand the Edges
I used my Dremel to sand the edges to have a nice finish... then I sanded them by hand to have the as straight as possible.
Step 7: Drill Holes
I used my drill press to cut small holes to screw the Arduino Uno in place.
Then I drilled a small hole in the bigger pieces for the connectors. I partly drilled with a bigger bit to help the connector stay in place and to have space to screw the knots under them.
Step 8: Let's Chisel for Components
I used a chisel and a mallet to "cut holes"... I don't know the right wording in English, but I removed part of the wood to have a place to put the battery holder and the breadboards.
Step 9: Let's Varnish and Solve the Puzzle
Then you need to varnish each pieces, I gave 3 coats with a light sanding in between each coats to have a soft finish.
When the puzzle pieces are together it looks like this... now let's install the components.
Step 10: Final Product
Here's the final product with all the components in place... now let's use it... to be continued ;)
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
    • Microcontroller Contest
    4 Comments
    Neat solution, but now that everything is so spread out, I think you'll need to buy longer jumper wires.
    I already did ;)
    Well done! Excellent idea. I may try to copy your design but with a 3d printer (I am too lazy to do it with wood...)
    Let me know if you end up doing it with a 3D printer, I would like to see the result.
    I would like to get a 3D printer some day :)
