loading
As a kid growing in Soviet Russia before Perestroika began, there were not that many toys, games and crafts available to you.
This puzzle is an example of the game that we were making using simple tools from father's toolbox and regular paper clips (bureaucracy provided infinite supply of paper-clips so they were quite easy to get),
(paper-clips and tools shown are not authentic although quite as regular and rusty)
Step 1: Straightening the paper-clip
Unwind the paper-clip with pliers or just by fingers (it's harder with bigger paper-clips).
Use flat part of pliers to make it straight where it was rounded.
Step 2: Ring
Make a ring on the end of the wire.
If it's not flat, use flat part of pliers to flatten it.
If it's too small, evenly press along it's length with pliers and it'll become bigger.
Don't make it too small (at least a quarter of the inch), but not too large either - see next step for proportions.
Step 3: Make one more ring
First, firmly grab the end of the ring with pliers and bend the long end of the wire perpendicular to the ring.
Then tighten the ring up slightly squeezing it with pliers.
Make another ring just like first one on the other end of the wire so both rings are in the same plane and the whole part can lie flat.
Step 4: Make another one and bend it as a bow
Make another one, make sure rings are of the same size before bending long tail perpendicular.
Bend second figure to make a bow with it's rings on the ends facing each other.
Step 5: Insert straight one into the rings of the bow
First, loosen rings of the bow with pliers, then insert straight part into the rings and tighten them.
Make sure rings on the bow don't let straight part get away.
We've made first part of the puzzle.
Step 6: Making The Heart
I call second part a "heart".
First we need to straighten third paper-clip and bend it slowly with fingers into U-shape.
Then squeeze it with pliers to make it narrow, but avoid a sharp angle.
Step 7: Making letter M from U and S
Measure a tip of narrow U to be a little bit longer then a diameter of the ring on the first part of the puzzle, grab it firmly with pliers and bend to make letter S.
Then grab another wire and bend it in the opposite direction so the face the same way.
Now if they didn't bend equally, use pliers to adjust.
Then slowly pull long tails in the opposite direction to get letter M (actually it makes anti-M - the outer strokes are diagonal and inner ones are parallel).
Step 8: Bend long ends to cross each other
Now, bend long ends of M to cross each other - you can make sharp angle or rounded one, it doesn't really matter since it's just going to be a handle.
Use pliers to give the part symmetrical shape.
Step 9: Twist the ends to make a handle
Once the shape is symmetrical, hold the ends above the crossing with the pliers and twist the ends with the fingers, try to distribute force evenly to make nice handle.
When it becomes hard to twist wires with fingers, use another set of flat pliers, make sure you hold on first pliers tight or it can start to bend the part above the handle.
Step 10: Cut the uneven part of the handle out
Most probably the end of the handle will look a bit uneven. Just use the cutting edge of pliers to cut it off.
Now, through the cuts into the garbage - it's very bad feeling when you catch them in the carpet with your bare feet. It also dangerous for small kids and they can die if they swallow them.
The second and last part of the puzzle is done.
Next step is the puzzle itself.
Step 11: The Puzzle itself
The puzzle is simple.
Two parts, "heart" and "bow" are separate, the goal is for heart to hang on the bow - see the images.
Try to solve the puzzle yourself before you read further.
Step 12: ALERT
ALERT - DON'T GO TO NEXT STEP (SOLUTION) UNLESS YOU GAVE UP SOLVING THE PUZZLE YOURSELF.
Step 13: SOLUTION
The solution is quite simple - slide narrow U-shaped part of the heart into the ring on the round part of the bow and push the ring on the straight part of the bow through the U, then slide the heart out of the ring and it's hanging on the bow.
Step 14: Variations
Obviously this puzzle was done in multiple variations - with sharp corners, square bows, large rings and so on.
Feel free to experiment - after all it only takes three paper-clips.
<p>this is a very nice puzzle, ticks almost everyone that attempts it and those who figure it out take a very long time to do so. I wanted to make this but I wanted it to be a little more permanent so I made it out of a wire hanger, because I cant just twist the end of the &quot;heart&quot; together I wrapped it in thin copper wire to make a handle and though it doesn't look as good as the paper clip version this will last a lot longer.</p><p>p.s. the shiny thing is a penny in comparison to the size of the puzzle itself.</p>
how do you put the ''heart'' on the ring?
check out last step
Do you have any more? <br>
No, just this one ;)
Very well written and illustrated !
Thanks for the post, was lots of fun.<br><br> For those who struggled on how to coil the ends of the straight bar and the loop, i found the easiest way was to hold the end of the wire with my pliers, but instead of struggling to make a perfect circle, I wrapped it around a pencil (circular) and then cut off the excess, giving me very neat circles.
This puzzle is great, I used to make tons of them, when I was younger. Though I used copper wire and soldered it together, but paperclips is a great idea, too. Keeps it a lot smaller than mine ever were.<br><br>Some tips:<br>I had done the trapped piece in the form of a heart. To get an even shape, I had drawn a heart on a piece of wood and put in nails around the outline. now I could just lay the wire around the nails and I would always have the exact shape I needed. If you plan on doing a lot of them, I strongly recommend preshaping every piece.<br><br>The puzzle works with 2 U shapes as well. You need a small U and a larger U. the larger U is created like your puzzle, the smaller U is hanging at the larger U (with the larger U going through the small U's loops). It becomes a lot more difficult, but it is solvable.
I Love it. it reminded me of my childhood. I had many like this.
Glad you liked it! It brought a lot of memories for me too ;)
Hey, is there any way to UNDO it without loosening the loop? please respond :D
Yeah, same way you did it<br>http://www.instructables.com/id/Puzzle-made-of-paper-clips/step13/SOLUTION/<br><br>but in reverse order ;)
HAhhaha yeah, i forgot the part where you push it back through the bow loop after the straight loop.... i feel stupid nowww.... hahaha thanks<br>
Wow! Thats really cool. I've made a couple out of thicker wire. They're great little gifts. Good job. <br>:o)
Great! Was it harder to make from thinker wire?<br>Do you have photos?
Yip, it was a fair bit harder, in fact the pliers gave me big blisters. <br>I'll take some photos as soon as I can.
do you know that u can add another bow to the first one? and u can still hang the &quot;heart&quot; in the 2nd bow! ill try to post it when i get one done. we had one of this when we were kids.
Yeah, please post it! I'd love to make one!
Haha got it! great instructable very detailed, I added a extra ring on the bow to throw off my friends
AMAZING!!! A little time consuming though. This is the type of situation in which you would like to be friends with Bender from Futurama.
It doesn't take that long once you know what you're doing - most of the time is reading the instructable ;)
Great Instuctable! You should put more puzzles up.
I don't remember any other ones - maybe if I google a bit, I'll do, but this one was classic ;)
These things are addictive!!!&nbsp; I haven't even solved my first one, and I'm already making a second!!!
Solved it, if only by dumb luck.&nbsp; Didn't look at the solution.
&nbsp;It's not terribly complex, but it's good puzzle at young age, for sure. ;)
&nbsp;Yeah, they are pretty cool - I made tons of them, it's always easier to make one then to find old one too ;)
Very cool, and as others have said very thorough. I have a box of paperclips one of my teachers gave me, so I'll make a bunch and sell em. :) 10/10
I should probably sell kits ;)
how do you make such perfect loops, mine are all squary
round nose pliers i guess, then just follow the curve<br />
Round nose are the best in this case. I actually used regular pliers, but very carefully shifting them to make round shape ;)
exactly what i did, turned out fine with regular pliers : )<br />
in soviet russia, loops make you!!
Just do it 100 times when you're a kid and you'll know ;) The other way is to use round-nose pliers ;)
Cool! Thanks for sharing.
this is awesome! great use of cheap materials!<br />
Thanks! This was the reason for creativity back then ;)
This is going to be another one of those things that makes me not work while at work. *Sigh*...<br />
&nbsp;I'm thinking about an office project with business cards and stapler - complete work killer ;)
Great job!.. just made one and I had troubles with making the loops rounded also. I can see how it would come naturally after making a few hundred of them though lol..
cool puzzle...
great i'ble interesting idea
lol, great 'structable but spell "throw" right! :P
I like it, had fun making it. as for solving the thing...i cheated lolz
YAYYYYYYYYY i figyred it out yayyyy
nice nicely done
Simple puzzle, but a great idea to use a paper clip to create a cheap puzzle. Thanks for posting this !!!
About This Instructable
47,765views
213favorites
License:
Bio: I love Internet and web especially. I also collect playing cards and interested in DIY, but lack time so I can't promise to have ... More »
More by Sergey Chernyshev:Puzzle made of paper-clips Party top-hat made of playing cards
Add instructable to:
