Pvc Arrow Quiver
11,453
193
6
Published
Introduction: Pvc Arrow Quiver
Step 1: Get Supplies
Get a 1 - 2 in pvc cap 1 - 18 in section of 2 in pvc 1 - length of para cord ( depends on you )
Step 2: Drill the Bottom Hole
Put the cap on the pvc, then drill a hole threw the side of the cap
Step 3: Drill the Top Hole
Drill a hole 1 in from the top directly above the previous hole
Step 4: Fish the Para Cord Threw the Bottom Hole
Step 5: Tie a Double Not on the Cord Coming Out the Top and Pull Other End
Step 6: Feed Cord Threw Top Hole and Tie Another Knot
Step 7: Load Your Arrows and Go Shoot
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    6 Comments
    If you want a hip quiver you could make a belt of paracord and add it to that.
    Great job I going to build it but in your title it should say through instead of threw because threw is the past tense of throw and to throw something means to launch it from you.
    Whoa this is mind-blowing. I've been using literally the exact same setup for 3 years now, except when I made it I used some multi-strand insulated electrical wire for the string. The wire finally broke last week so I replaced it with some 550 para cord. Great minds, right?
    This simple design works perfectly and could only be made batter with a more comfortable sling.
    I also stuck a chunk of insulating foam at the bottom of the quiver. This way if I want the arrows to be more secure, I just push them into the foam and they won't fall out even if the quiver is turned upside down.
    Beautiful! Simple and effective. Would go well with my last project:
    https://www.instructables.com/id/15-Minute-PVC-Bow/
    Yeah, I'm gonna have to make one now. :)
    You did a really good job of explaining this concisely with pictures. Thanks!
