Pwr laptop cooler
Pwr laptop cooler
I as of early 2006 I could not find a powerful enough laptop cooler that was good for my use. So I made one myself. It's been working great for me so I thought I would share with others.
Disclaimer: DO THIS ON YOUR OWN DISCRETION AND RISK AND THAT YOU WILL BE SOLELY RESPONSIBLE FOR ANY DAMAGE OR INJURY.
Here is what you need.
Medium Fedex box.
Two VHS tapes.
PC Fans. ( I use two 120mm Antec 3 step speed control Quite fans)
PC ATX power supply.
Small zip ties.
Large zip ties..
Step 1Cut the box
Cut the box
You can make it esay on yourself and use a medium Fedex box like I did.
Cut the box like the picture.
Start with the bottom part that is going to rap around the box.
18 comments
Sep 18, 2009. 4:47 AMgerthedj says:
Dude th fans should suck the air out and no need for a bulky ATX power supply just convert it to USB
Nov 9, 2009. 1:57 PMSmAsH! says:
it would draw too much current and fry the port.
usb ports can only supply 500mA, motors draw heaps.
Jul 7, 2007. 5:41 AMslater101 says:
If those are 12 Volt fans then why are you using a power supply you could have made it usb powered or used a 12 power converter and plug it right into the wall check out mine to see what im talking about...
click Here
Nov 9, 2009. 1:56 PMSmAsH! says:
uhh, usb is 5v, and a converter would draw too much current from the usb, frying it.
Sep 7, 2008. 11:55 AMKulawend says:
USB output is 5v not 12v.
Mar 11, 2011. 5:04 PMGsE-Lance says:
It's called Op Amp
http://en.wikipedia.org/wiki/Operational_amplifier
Mar 12, 2011. 1:36 AMKulawend says:
Yes, I know what an op amp is.
And thanks for replying to my 3 year old comment.
Jun 19, 2008. 4:10 PMmacwhiz says:
luv it! :)
May 24, 2008. 9:28 AMpukemon says:
that is what i call gheeeeetto! but i like it. nice job.
Oct 25, 2007. 9:03 PMshooby says:
This seems pretty bulky. Couldn't you use similar sized fans but make it a little smaller. For example, you could put the fans at an angle, taking some depth away for the device. It does looks like it's easy to make, and effective.
Jul 4, 2007. 9:33 PMmallmand says:
Sweet, I like the looks and the usefullness, I am trying to build a laptop rack with cooling and this idea has helped.
Jul 3, 2007. 9:09 PMPseudonym says:
I have a query, are the fans blowing air under, or sucking air out. If they are blowing under - as my laptop would need - what kind of output do you get. I ask this because it seems like the airflow might get disrupted by the hape of it. Other than this, and possibly some more info on rigging the fans to the psu, a great idea.
May 1, 2007. 1:09 AMbucci says:
couldn't u have just spliced the fans into a usb cord so that u don't have to lugg that power supply along
Jul 3, 2007. 9:06 PMPseudonym says:
no, usb wouldn't put out enough power to drive them both. Lower powered fans would work, or an inverter, or a ipod usb connecter spliced in - i think -
Mar 16, 2007. 1:03 PMTeacherOfTheWays says:
Good idea. Another thing you could have done was extend the box and cut holes in the top. That way the laptop could have rested on the box while still cooling it off.
Mar 15, 2007. 5:27 PMledzeppie says:
so what the hell are the vhs tapes for??? i must have missed it...
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:woosh3
