Q-tip Crossbow
23,280
192
10
Posted
Introduction: Q-tip Crossbow
Simple Q-tip crossbow 3d printing design.
Instructable by:DeLaina McDonald and Serena Nguyen
Step 1: Step 1: Making the Design
You can use various 3D CAD programs in which to design this project, such as Onshape and 123D Design. Below are the STL files for the design we used.
Step 2: Step 2: Printing the Design
After getting the STL file we opened it into the printing software, Cura. You can download this for free from the internet. Orientate the pistol so that the handle in sticking up in the air, this way little supports are needed. You will need to add supports, which you can do so by checking the box on the left. Also orientate the trigger so its on its side, therefore no supports will be needed. Print the design at 15-20%.
Step 3: Step 3: Remove the Supports
You can remove the supports from the back of the pistol simply by pulling it off. If some pieces do not come off with the first initial piece you can use an x-acto knife.
Step 4: Step 4: Putting the Pieces Together
After removing the supports; insert the trigger piece into the opening under the body of the pistol. With a 2/56" screw, secure the trigger to the body. A screwdriver may be needed. Take two regular sized hair clips and break off the smaller middle piece. You can do so by bending it back and forth a couple of times. Afterwards, insert the two clip pieces into either side in front of the pistol. Next, take a rubber band and insert it into the hole of the clips. Tie ONE END only. Test the pistol with a Q-tip before securing the other side to ensure maximum length shot. In addition, make sure all Q-tips have one end removed before using as ammunition.
Step 5: Step 5: Shooting the Gun
To shoot your gun, wrap the rubber band around the small ledge at the end of the pistol. Then, place the Q-tip fluffy side out on the ridge until the end meets the rubber band. Be careful not to push the Q-tip in to the ridge too tight. You won't be able to shoot! Pull the trigger. Enjoy!
  • Paper Contest 2018
    Paper Contest 2018
  • Sew Warm Contest 2018
  • Epilog Challenge 9
    Epilog Challenge 9
10 Comments
Cool!
Is this your own design? Because this looks extremely similar to a design I saw over at thingiverse almost 2 years ago: http://www.thingiverse.com/thing:509659
As atene has pointed out; it looks like an exact copy from thingiverse.com. Instructables is meant for showing new and original ideas, unless that was your original on thingiverse. Was it?
It's a bow, not a gun. Projectiles nonetheless.
Minus the trigger, couldn't this be made with with a disposable razor?
Sure it' fun, until someone pokes an eye out. Then it is hilarious!
:-) Or would it be "pokes an ear out"? :-) After all, these are q-tips we are firing off. :-)
cool be funny to use in the office haha lol
Going to print one tomorrow just for fun
Thanks for sharing
Much wow. Such a great instructable. My kids would also love these. Thanks for sharing!
