Qev Air Gun
22,162
24
21
Posted
Introduction: Qev Air Gun
To build the QEV air gun you will need a list of parts
What you need:
1kg dry powder fire extinguisher
Tubeless tyre valve
Quick exhaust valve (QEV)
2X Double 1/4" male adaptor
Double 3/8" male adaptor
1/4" female to 3/8" female adaptor
20mm X 1.6mm Aluminium plate
2X big hose clamps
Air duster trigger
Epoxy glue
Step 1:
there are three ports, the top one used to have a pressure guage and is now filled with epoxy to fill the gap.
Step 2:
Emtpy out the fire extinguisher and paint it. Then separate the to peices and drill a hole somewhere in the fire extinguisher for the tyre valve to fit in. Drill another hole in the 20 X 1.6mm aluminium plate and put it over the tyre valvle and secure with two big hose clamps as shown in the second image.
Moving on to the second piece which is shown in the first image. Grab the double 3/8" male adaptor and Using plumbing tape rap it around one of the ends. Using a shifter tighten it on the end where the nozzle used to be. You will find it hard to screw it on because the fire extinguisher has a thread that is different thread which is hard to find, so you will have to force it in as tight as you can and put some epoxy or silicon around it so it doesn't leak.
Step 3:
Using the QEV, two double 1/4" male adaptors and a 1/4" female to 3/8" female adaptor screw them all on the the QEV as shown in the picture.
You may notice some aluminium plate on top of the QEV, that is my homemade scope railing I make from the left over 20 X 1.6mm plate and some 10 X 3mm aluminium plate.
Step 4:
And after that all you need to do is make a barrel.
If you have any questions please leave them in the comments bar below and I will try the answer them
  • Microcontroller Contest
  • Spotless Contest
    Spotless Contest
  • Science of Cooking
    Science of Cooking
16 Comments
wow bro sick stuff
Nope I'm happy to give the qev a go. Re the 1/4 qev you posted a link to ebay is it important to get just that one or will any 1/4 qev work?
hi again, yes you can get any type you like just make sure it's 1/4" so that it fits. If you end up using a fire extinguisher check the rating for the pressure, you may have to convert it. And then look at the rating for the QEV you want and check if it can hold that pressure because if the QEV is made to hold 100psi and you pump the tank to 200psi it will probably leak.
Great simple design, well done. Question, rather than using a tyre valve on the cylinder, would it work if you held open the red cylinder trigger and the air gun trigger then pumped air through the bottom of the air gun where it vents?
Hi TargetOz, Your idea about pumping air through the barrel while holding down the two valves could work but it will firstly take longer to pump and there can not be any leaks from the barrel to the connector, maybe put some silicone around the connection or putty for extra strength. But I wound suggest doing it the way I did because it's a lot easier. BTW you don't have to use those metal straps that hold the valve if that's what's stopping you from doing it my way. Please ask as many questions as you like and don't forget to tell me how you go.
Oh sorry I didn't read the question properly. Yes your way should work, just don't forget to take off the pump when it is finished being pumped
Thanks again. Some dude here says there's no need for a qev. Why would he say that?
hi, the reason he said that is because the fire extinguisher has a similar valve to the QEV so you could just connect the barrel to the valve on the fire extinguisher but it would be hard to shoot because the trigger would be facing the other direction. The reason I did it my way is because the air comes out more suddenly making it shoot Faster, but if you want an even more simple design then you could just connect the barrel to the fire extinguisher valve.
would it go further with a CO2 tank and were did you buy the qev
Hi there, if your looking for a QEV than eBay is the place to go:
http://www.ebay.com.au/itm/1-4-BSP-Pneumatic-Quick-Exhaust-Valve-Quick-Release-Air-Aluminum-Alloy-/121364964567?pt=LH_DefaultDomain_15&hash=item1c41ea64d7
This QEV ships worldwide from China, so might take a while to get to you depending on where you live.
Also with the co2 tank, it doesn't matter what you use as your tank, whether you use a pvc pipe, a fire extinguisher tank, a paintball tank or a soda stream co2 tank. It doesn't really matter what you use because it just depends on the amount of pressure there is in the tank.
