Introduction: Quad-Pod
this is a cheap and easy way to make a tri-pod or in this case a quad-pod
Step 1: What You Need
- Plastic cup
- Bolt -  this is used to screw into the bottom of the camera or camcorder you have (make sure its the right size)
Hot glue
- Scissors or knife
Step 2: Step 1
Poke an  x-shaped hole in the top of your plastic cup, then slide the bolt through and  hot glue it into place.
Also instead of using the bolt  you can use an old iPod  USB connection cable and cut off the twenty pin plug(the part that sticks into the iPod )  you would only need one  long cut  in the top of the cup and hot glue it on.
Step 3: Step 2
Cut up the sides so there's  four tabs  and also cut off the rim of the cup
Step 4: Finish
The final product should look like this
    • Science of Cooking
      Science of Cooking
    • Trash to Treasure
      Trash to Treasure
    • Pocket-Sized Contest
