3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Quadratic Formula for the TI-83 and 84
   Have you ever wondered if there is a way to make your calculator solve quadratic equations for you?  Well, there is a fairly easy way to make your calculator do all the work for you.
Another program that I have put on Instructables is Heron's Formula.
www.instructables.com/id/Herons-Formula-program-for-the-TI-83-and-84/
Step 1Getting started
Getting started
   You should know that a quadratic equation looks something like this: x^2-3x+2=0 or ax^2+bx+c=0.  This will be important later on.
The first step is to press the program button on your calculator.  Press the right arrow twice to get to new and select create new.  Enter a name.
   Now press program again and press the right arrow then press 2. To get letters, push the alhpa button.  Now enter A,B,C and hit enter.
17 comments
Feb 29, 2012. 9:45 AMJordan Dyck says:
wow i just spent the past 4 months struggaling through math only to find this after i passed
Feb 17, 2012. 12:17 PMiskate24.7 says:
Hello. How does this program respond when the solution is an imaginary number(when the graph of the equation doesn't have a x-intercept). Can it display the exact solution(s) or does it just give an approximate solution in decimal notation. If it cannot display the exact solution, is there an easy way or simple alteration in the programming that can be maid to make this possible. As you can probable tell I do not actually have a calculator yet, so I can't really experiment. I will have one soon though, and it would be awesome if I could use it for this purpose. Thanks in advance for any help/time!!!
Mar 2, 2011. 2:39 PMMicheVonWitch says:
hi. when you're putting in the numbers into the program, and say the equation is 12^2+x^2 =13^2 , how do we arrange it, and do we insert the power of the exponent into the program as well? thank you!
Mar 15, 2010. 8:44 AMlililijason says:
Hi... First i have to thanks you for posting such a awesome program onto the internet.. i followed all the instructions but i found out that the answers came out are slightly different from the correct answer. The negative and positive signs of the 2 answers have been swapped. I want to know it's my problem with my program or.. the error of the program? (i check several times)
Mar 11, 2010. 7:03 PMKlaudiuszm says:
i made same program except with the works. was the first program i made just by looking off the source on my teachers calc.
Feb 23, 2010. 7:06 PMsjoobbani says:
 Thank you.
Feb 12, 2010. 8:29 PMvalhallas_end says:
Heh...its funny.  After years of math in college and engineering classes, this has always been the first formula I've programmed into every calculator I've owned.
Feb 12, 2010. 1:19 PMadityasingh says:
Thanks so much. I really appreciate it!
Good job on the guide!
Jan 31, 2010. 3:54 AMerror32 says:
You might want to display the result of (B^2-4AC) as this determines the results. if it's >0 the results are real, if it's 0 then the two results are the same and if it's < 0 the results are complex (you can display the answers by selecting "a+bi" in the [Mode] menu
Jan 30, 2010. 10:26 AMFutience says:
Thnx!!! I really like this one, very handy for school :P. nice tut.
Jan 29, 2010. 5:52 PMSWSOE says:
Nice tutorial. I wrote my own program to do this a while back which implements a command included with the OmniCalc application.  It will take the square root of a number and out the simplified version. Quite useful for displaying the answer in exact form when the answer is a never ending decimal.
Jan 29, 2010. 7:36 AMgantyman says:
i tried this and when when i put in the numbers it displays
"X=,X,Y
Done"
help!!!
Jan 29, 2010. 10:00 AMbeta1072 says:
close the quotes after the equals sign
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Scout Jinx
