Step 4Coin pouch
Cut one piece the length of the right pouch (3 1/2 inches 9 am)
Cut 2 pieces the length of the wallet (8 inches, 20 cm)
Again, overlap the long pieces to make them the height of the wallet.
Make a loop with the long pieces the width of the pouch (Wrap around a card)
Add the short piece on the bottom of the roll to create the bottom of the change pouch.
Place this pouch on top of the other. Start with the right side first to get the placement as it is easier to remove from the non sticky side of the tape.
Cut 2 pieces of tape 4 1/2 inches long (11.5 cm) (about an inch bigger the the pouch)
Place on on the top of the pouch line up the top of the tape with the top lip. wrap it inside the pouch and to the outside of the wallet.
Cut a piece 4 inches long (10 cm). Make a roll the width of the tape (slight less the 2 inches (5 cm). You can also make it roll around a card (short end) but I like it a bit smaller then that to make ti the width of the tape. Place this centre and on the bottom of the pouch
Place the second 4 1/2 piece on the bottom, line up with the top of the smaller pouch and wrapping inside the left pouch and to the outside of the wallet
Cut 2 pieces the length of the pouch (3 1/2 inch , 9 cm). Use one of them to cover up the bottom of the pouches.
Place the other beside the wallet. Mark with a pencil the lines for the middle and top pouch, allowing a bit to go over the coin pouch lip. This will be our lip cover and back cover for the little pouch. Do the same for the width. Cut the corners on these lines. It should resemble a superman symbol.
Place it over the top lip at it's widest point and fold over. Tuck the bottom inside the small pouch. (You could do this with two much simple pieces, but this looks better.)
Cut a 1/2 inch piece of tape (1.5 cm). Cut the corners off and place it on the lip of the small front pouch.
comments
Add Comment
Add Comment
