Step 5Coin pouch Flap
Cut 2 pieces the width of the pouch (3 1/2 inches, 9cm)
To ensure the flap comes down enough place one of these pieces face down in line the the small front pouch. Keeping it line, wrap it oer to the inside of the cash pocket. then peel it up off the front of the pouch. Place the second piece in line with the top of the flap, and have it go into the coin pouch.
Cut about an inch (2.5 cm, the height of the flap) of tape and cut it in half. Cut it in half again. Use two of these pieces to close the side of the flap
Cut a piece 2.5 inches, (6 cm). Centre it inside the pouch coming up and over the flap. Fold the end of the tape into a triangle.
Cut two more pieces about the length of a card. Place the tape inside the cash part of the wallet flush with the flap.Split the tape where the triangle starts fold the thinner flap into the pouch. Trim the remaining tape to the height of the triangle. Fold over the triangle. Repeat for the other side.
Tuck the triangle into the front pouch and your done!
If you want you can put some tape over the outside edges to clean up the back, but that is up to you!
The final wallet itself looks quite nice but it does make for a pretty thick wallet before any money is placed in it, due to the many many pieces of tape used. If there was a way to refine the design to reduce the quantity of tape it would be easier to put in one's pocket.
