Quick & Easy Bicycle Skirt Guards
 by 1lenore
Featured
Step 1: Gather materials
You'll need a bike with fenders, a handful of cable ties, and a couple of pieces of tulle or mesh slightly larger than your fender. A cruiser or touring bike will work best, but you could adapt this to a bike with a cargo rack or a seat post mounted fender with a couple of holes drilled in it. Tulle is cheap at any fabric/craft store (mine was on sale after halloween) or can be scavenged from old formal dresses. It is reasonably strong and doesn't hold dirt very well. You can spray it clean pretty easily, too.
Step 2: Prepare fabric to be attached to bike
Cut the tulle to a semi circle somewhat larger than your fender. The straight edge will be going from the rearmost fender stay to the front of your chainstay. Pick a spot close to one of the corners and stab a cable tie through. Tulle is tough, so push hard - don't be afraid.
Step 3: Attach to bike
Start on the non-drive side of the bike (usually left, but some tandems have both sides.) Wrap the cable tie around the fender stay and poke it back through the tulle. Attach the cable tie snugly to the fender stay and repeat on the chain stay so that you have the bottom line of the fabric going just above the hub. Remember, you want to be able to change a flat, so access there is important! Now attach the cable ties to the second fender stay and the seat stay. Once you get it all lined up, tighten all your cable ties well. How taut your skirt gaurd stays will depend on how tight your cable ties are, so tighten them very well - a pair of needle-nosed pliers can help with this. Now trim your cable tie ends.
Step 4: Drive train side
The difference on the drive train side is that you have to be cautious about not getting in the way of your chain. My chain guard has a handy attachment I used as a guide for where to cable tie it, but most modern chain guards won't have that. Aim for a spot just behind where your pedal travels. You've already got the chainguard (I hope!) to partially protect you. You're aiming to keep your skirt from wrapping around the seat stay or rear cog. Again, start with the straight line from chain stay to fender stay, and then add the seat stay and second fender stay cable ties.
Step 5: Make it all purty
After tightening and trimming the cable ties, trim the excess fabric from one connector to the next in approximately a straight line. It will end up with a nice almost-spiderweb shape.
Step 6: Cruise in safety and style
Check to make sure your fabric isn't loose or rubbing the tires (or worse yet, chain) anywhere. You are ready to roll!
1-40 of 43Next »
guitargirl98 says: Jul 21, 2012. 11:21 AM
Any ideas for building them on a bike without fenders?
1lenore (author) in reply to guitargirl98Jul 22, 2012. 1:46 AM
Put fenders on?
Seriously, you need some sort of framework to attach the skirt guard to, and fenders are a good way to provide that structure.
meradera says: Sep 19, 2008. 12:26 AM
Great idea! I'm testing window screen material, and so far it is holding up okay. Does anyone have an idea how to construct a chain guard?
milesfromneihu in reply to meraderaJun 20, 2012. 1:12 AM
I made a chain guard from a large cookie tin. The steel was quite thin, so I used a double layer, stuck together with double-sided tape, plus a few pop rivets. It attaches with screws in three places: bracket with two screws into down tube, clip-on bracket to chain stay, and clip-on bracket to seat stay.
kaiplusjosh in reply to meraderaOct 27, 2010. 4:36 PM
if you have the old chain guard you can take some sheet metal and cut out your shape then drill holes thro the chain guard and your sheet metal then bolt it together and that way you can paint it how ever you want
rgrimm1 says: Mar 2, 2012. 3:38 AM
You can add eyelets to a fender IF the fender is stiff enough to take the slight tension of a skirt guard.
My mother also had a HEAVY bike with the full skirt guard and chain guard...it was made in the 1930's.
A chain guard could be made of choroplast, but I'm making ones of brass for our bikes...I like to Steampunk stuff up! It will go well with the Steampunked baby carriage.
The skirt guard for SWMBO will be of canvas with brass eyelets for lacing it on, and stiff wire for keeping the edges taut. Dark colours are recommended unless you like removing it often to wash...Scotchgard is also recommended.
firetrucks says: Jul 28, 2011. 8:31 AM
This is so clever!! I have a lady bike and I love dresses and long dramatic coats, so I'll definitely be using your method. I want to hem the tulle, though, and maybe even use eyelet tape, so I have to wait til my sewing machine is fixed :( but I promise I'll be back with pictures in a few months. I love that this is so lightweight, and I'm floored that yours have held up for five years!
Kay Schmidt says: Jul 29, 2010. 1:03 PM
Where were you 45 years ago when i had an imported embroidered skirt munched by rear wheel, arrived at high school class late, tear-stained, all discombobulated and sweaty? (Not born yet, I know.) Am looking forward to getting bike and riding again, very glad to see your intructable!! Am visiting sites pricing helmets, speedometers, lights, gloves, jerseys, and the all-important etc. Any suggestions or comments anyone has to help in this are certainly welcome. And I am so glad this site exists!! Thanks.
1lenore (author) in reply to Kay SchmidtJul 29, 2010. 1:16 PM
The site I'm currently ogling for beautiful cycle accessories is The Bicycle Muse. I really dig the oilcloth panniers. The helmets are cute, too, and they have reflective spats!
Kay Schmidt in reply to 1lenoreJul 30, 2010. 8:48 AM
"Reflective spats ... hhmmnn" Thanks for the more to think about and look at.
brittaful says: Jul 20, 2009. 4:48 PM
wonderful! i used floral wire instead of cable ties, but am really happy with the results! brilliant idea, thanks! http://www.facebook.com/album.php?aid=2193772&id=16114732&l=4110a8ec4f
kreuzberg in reply to brittafulAug 1, 2009. 8:26 AM
that looks really neat. i just found a website that sells skirtguards in america (www.theurbanbicycle.com) but if that doesn't work out, i'm definitely trying this.
1lenore (author) in reply to brittafulJul 20, 2009. 5:35 PM
Your bike looks great! Perfect that you used what you had on hand, too.
wolfybrie says: Dec 13, 2008. 9:14 AM
My skirt only ever gets stuck in the back brake, so I don't think this one will work for me unless the fabric went over the metal guard. But once I get my new bike I'll try it out similarly.
Knox O says: Jan 27, 2007. 5:15 AM
Wow! That's so cool - and so practical. My realisation that 'I'm a lady' has coincided with my starting to cycle to work, so now I can achieve both - hopefully in style! And I agree with Caya - gorgeous bike! ;o)
1lenore (author) in reply to Knox OJan 27, 2007. 1:47 PM
Thanks! If you do make your own skirt guards, I'd love to see how they turn out. Interestingly, there is now (finally!) a bike being sold in America with skirt guards: the Electra Amsterdam. However, I still haven't seen any skirt guards sold separately for outfitting your favorite bike.
inkstainedheart in reply to 1lenoreSep 8, 2008. 4:07 PM
There's one on Amazon.com for guys. It could use a good paint job, but it otherwise looks pretty decent.
1lenore (author) in reply to inkstainedheartSep 8, 2008. 7:16 PM
Thanks! I've never seen the Electra Amsterdam skirt guards sold separately from the bikes before. They might not fit all bikes, but it is good to see them out there.
PrimeGuy says: Aug 3, 2008. 6:18 PM
Thanks 1lenore.....I have found 'skirtguards' for sale but for some reason I cant add the photo here at this time.....I can send you a photo of it via....zzprimeguy@yahoo.ca.....regards, Jack
geowulf says: Mar 5, 2008. 9:48 AM
You could totally use coroplast sign board (there are always a million of them during an election year). Great idea!
PrimeGuy in reply to geowulfJul 31, 2008. 11:51 PM
Great Idea....Have you done this on a bike yet? How would I go about installing this signboard?
1lenore (author) in reply to PrimeGuyAug 1, 2008. 9:45 AM
I have not used coroplast, but I have used cardboard. You do it pretty much the same way - make holes for cable ties where you want to attach it to the struts.
chris_too_cool_for_school says: Jul 17, 2008. 10:51 AM
Aw, that is a beautiful bike, improved with a brilliant idea. Cheers!
vrkelley says: Jan 21, 2008. 3:40 PM
I'm not sure how long that would last without ripping out. Esp on fast descents. Guess it's just for going around 8-10mph.
1lenore (author) in reply to vrkelleyJan 21, 2008. 5:06 PM
This bike weighs over 40 pounds, so I don't get going very fast very often, but I never had any problems with fast descents when I made them. I have had these skirt guards on my bike for about five years now (with off-and-on heavy use) and they have not ripped at all, but have stretched a little. If you're very concerned about long term strength, I would suggest using canvas instead of tulle, putting eyelets or buttonholes in the canvas and then using cable ties to attach to the frame. However, you would need to hem the canvas to prevent fraying.
bedbugg2 says: Aug 12, 2007. 5:24 PM
you have a tricked out ride
Karpov says: Sep 4, 2006. 9:09 AM
I don´t speak English. Sorry.
bedbugg2 in reply to KarpovAug 12, 2007. 5:21 PM
you just spoke it lol
swede d hied says: Nov 24, 2006. 6:38 PM
would your contraption be of use to a young scotts laddy cause ma kilt plays havoc with ma spokes ah know it looks gie bonny but can ah change yer colours tae suit ma clans tartan or kin ye draw up one so i kin see if it passes muster ......keep on groovin as they say.swede
HeresyOfTruth says: Nov 10, 2006. 1:27 PM
Perfect! I am in the process of buying a utility/commuter bike, but could not find anywhere that sold skirt guards. Now I will just use your method, from your very excellent tutorial.
1lenore (author) in reply to HeresyOfTruthNov 10, 2006. 11:09 PM
Thanks! That is what it's all about.
captain_cardboard says: Oct 25, 2006. 10:35 AM
Hey, do those christmas tree lights work?
oskay in reply to captain_cardboardOct 26, 2006. 1:25 AM
They do; I've seen it. You can see the green battery box next to the hub. They even light up in sequence, which looks pretty neat when it's rolling.
WPee says: Sep 24, 2006. 11:17 AM
Hello Ladies, Guys also like skirts (but we don't wear them - grin) I do recall a young fellow who used a piece of alumimum and POP-Rivets and BOND-DOUGH and a really excellent metal flake paint job. My guess is it's about time for that design style to make a RETURN. It may also INCLUDE such things a LEDs and GPS and up-to-date goodies.....LET THE PARADE BEGIN....
sandma1half says: Sep 19, 2006. 2:08 AM
Nice Idea! I love to wear skirts with my bicycle b/c it makes the ride feel more pleasant and less like a regular commute. I have even flirted with the idea of wearing semi-formal gowns on a bike, and now that I know how to make a skirt guard, I may just try it! Thanks!
1lenore (author) in reply to sandma1halfSep 24, 2006. 12:49 AM
Yes, skirts are ideal for riding a bike - you stay nice and cool. Well, a long polyester satin skirt won't be chilly, but generally speaking skirts are way more comfortable.
skautistic says: Aug 27, 2006. 9:51 AM
Is this just for looks, or does it serve a purpose other than looking fabulous?
1lenore (author) in reply to skautisticAug 28, 2006. 9:18 PM
This really does keep your skirt from getting wrapped around your seat stays, caught in your chain, or otherwise preventing you from getting there safely. I have several long dresses that I can wear riding this bike now. One of them has holes in it from wearing it while riding prior to installation.
skautistic in reply to 1lenoreSep 5, 2006. 8:00 AM
Hence the name skirt guard, sorry for the stupid question everyone.
yitong leo says: Sep 3, 2006. 9:55 PM
fairy tale dream
1-40 of 43Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
