Remove these ads by
Signing UpStep 1Ingredients
2. Peanut butter, jelly, or if you're allergic to those, you can always use water.
Remove these ads by
Signing Up| « Previous Step | Download PDFView All Steps | Next Step » |
All Steps Viewing
http://www.snopes.com/humor/iftrue/antpoison.asp
I don't know about aspartame's efficacy against ants one way or the other. I use borax personally. That's VERY effective against all sorts of pests and it also doesn't leave a sticky mess behind. I even use it to clean my windows, works better than Windex!
High levels of Phenylalanine can cause brain damage. It should also be said that those that are at risk (PKU and pregnant women with hyperphenylalanine) must also watch their protein and milk intake for the same reason. The reason aspartame products contain a Phenylalanine warning are for those people that must pay attention to that amino acid (not really expected in sugar products :p)
At any rate, it has been observed that it does, indeed, kill insects...
Can you cite credible sources?
For Thoroughness....
FDA
And here's an MIT study that gave high doses of aspartame to subjects for four months... Conclusion - no difference
MIT Study
I personally am sticking with cane sugar where possible. Why? I prefer the taste and texture (and prefer not depending on corn so much).
aspartame does not kill ants.
http://fireant.tamu.edu/research/projects/pdf/pgs33-35.pdf
Fix you homes gaps If ants are getting in, heat is escaping etc.
Clean up your mess Ants generally only seek heat and nutrients.
Follow the trail If you want to actual remove the ants, follow the trail and pour boiling water down the nest. No poisons needed.
This is a awesome I'ble!! I have a dog and cat, if I was ever in need of a "poison" I would follow this guide. Thanks!!
