Quick, Cheap and Quality Parallel Clamps
8,364
189
16
Posted
Introduction: Quick, Cheap and Quality Parallel Clamps
A woodworker can never have too many clamps and when you are a newbie you would be sadly lacking in that department. Especially if it's a hobby and you don't want to spend to much.
So what do you do when you need parallel clamps for gluing up and don't have any clamps available? You improvise! I always keep my eyes open when I see carpenters working to see the tricks they use. This is one trick that I am really grateful I saw!
Step 1: Basic Scrap
You can use the materials you already have and make any amount of parallel clamps for a fraction of the cost or even virtually free
It is easily made from scrap material and you can be adjustable for varying widths of material to be glued.
For each clamp you would need -
  • 1 beam
  • 2 small blocks
  • 2 screws
Step 2: Mark the Width
Place the boards that are going to be glued up together. Place the wooden beam across it and mark the width.
Step 3: Drill and Screw
Now place small blocks under the beam. The blocks should be placed a little away from the required width for glue up. Drill pilot holes and then drive the screws through the beams and into the blocks.
The distance between the blocks should be the width planks to be glued up plus about 1/4″.
Make as many wood parallel clamps as necessary.
Step 4: Glue It!
Glue the edges to be clamped.
Step 5: Join It!
Now join the glued edges and make sure to place a piece of plastic or wax paper on top. Remember, your clamps are wood too! You do not want to glue your clamps to your project!
Step 6: Place Your Clamps
Place your clamps on top of the work piece. Again do not forget the plastic sheet to be placed between the clamps and work piece.
Step 7: Tap Away
Now simply tap the blocks to create an evenly distributed pressure along the glue joint.
Step 8: Nice and Tight!
The tightened parallel clamps will give and even clamping pressure and will produce a nice, tight joint.
Step 9: The Other Side
Here is the other side still in the clamp. I can't imagine anything easier than this! As my kids say ' Easy Peasy Lemon Squeezy!'
Hope this helps you in your projects ! I found it very helpful as it also helps me to clamp up wood while I used my kreg jig.
Please don't forget to vote for the tools contest! I would really appreciate it! Thanks!
  • Sew Warm Contest 2018
  • Gluten Free Challenge
  • Minecraft Challenge 2018
16 Comments
(Simple + Useful + Easy to do) = Thank you.
Your Welcome! glad to help :-)
Such a simple idea and has now given me a use for the 4 bars I salvaged from my cheap quick clamps that no longer work, multiple holes for different widths.... perfect.
Only thing I would add is gluing a patch of sandpaper to the inside gripping faces to increase the friction so they stay tight.
Thanks for the tip! Will incorporate it :)
I was thinking about this clamp- if the boards are long enough, the length of the clamp does not matter as long as it is at least the width of the boards. In other words, you can make an the clamps longer and use them on a variety of width boards.
Yes, one side you permanently keep screwed, the other moves up and down according to the width of your project! . It's so easy that if you need more, you can make it in minutes from off cuts!
Thank you so much!
That wood you're joining has some gorgeous grain.
It's rubber wood. It's the cheapest hard wood, hence I work quite a lot with it. This wood is very strong when it is treated.
