Quick Cheap Easy Shelf!
30,422
274
17
Posted
Introduction: Quick Cheap Easy Shelf!
Need some Quick shelving?
Need some Cheap Shelving?
Need some Easy Shelving?
You can make this instructable in less than 30 mins, with limited tools, for less than £15 ($18)
Step 1: Step 1: Material Required
For this shelving you will only need 2 pieces of timber - 1 x 8ft (2 x 4) + 1 x 8ft (1 x 6)
I have added pictures of these 2 pieces that i used. I had these left over from previous projects but I estimate that in total the cost of buying these pieces would be approximately £6 ($8)
In addition to the wood, all that is needed is a number of screws. Here i used 4 x (8 x 100) Rawl screws per upright, which have the rawl plug attached and dont require any pre-drilling and accurate lining up with the wood. For these, the rawl plug and screw go straight through the wood and into the wall. Much handier and quicker than traditional methods. You can read more about the screws I used here but normal screws and rawl plugs would work just as well if this is all you have.
I didnt photograph this part but I have drawn a CAD illustration of how the 2 x4 is mounted to the wall using these screws. I cut the 2 x 4 down into 800mm lengths and placed them on the wall 1500mm apart.
Step 2: Step 2: Cutting the Timber
I set up a stop block on the mitre saw to cut the overall depth I wanted the shelf to be. As I am making repetitive cuts I set the stop block to 250mm and cut the 1x6 board into smaller pieces.
Following this I set a freshly cut pieces at an angle leaving approximately an inch at each end. The reason for this will become apparent in the next step. When I was happy with the line I had drawn and how it lined up with the blade, I made the cut. NOTE: MAKE SURE THE PIECE IS SECURE AGAINST THE BACK FENCE AND HANDS ARE KEPT WELL AWAY FROM THE BLADE DURING THIS CUT.
When the cut is made you will be left with your finished piece and a small triangluar piece. This 'waste' piece will now become your guide for future cuts. By setting it against the back fence it creates the angle you just cut on the original piece for future pieces to follow. When you line up the next pieces with the tip, it creates the exact same angle you cut previously meaning you can make multiples - for this shelf section you will need 8 pieces.
When you are done you should have something that looks like the last picture.
If you dont have a Mitre Saw, a hand saw would work just as well. Use your first cut as a template to mark the future pieces and cut along the line.
Step 3: Step 3: Assembling the Pieces
So with the angled pieces I cut, I added them to a top piece which is the same overall length. These parts are simply glued and screwed together.
When they are assembled, simply place them onto the 2 x 4 uprights and secure them in place with screws at each side as shown in the CAD model.
NOTE: When mounting the lower shelf supports, the top part of the shelf arm will need to be reduced in order to fit around the upright. This is shown int he last CAD model. The assembly process is the same. This too is held in place with screws on each side, as before.
Step 4: Step 4: Load It Up!
I used this quick easy and cheap method of wall mounted storage to hold some previous projects which I had made - modular shelving! They were taking up floor space that i need in my workshop so I wanted them up and out of the way. As you can see from the pictures, it works for me and I was actually surprised how much weight these simple wall brackets can support. I have had them in place for about 3 weeks now and they are a welcome addition to my work area.
Thanks for reading and good luck making!
  • Microcontroller Contest
  • Spotless Contest
    Spotless Contest
  • Science of Cooking
    Science of Cooking
15 Comments
Nice idea. If you drill regularly spaced holes through the verticals from side to side, and through the shelf holders, you could use dowels or metal rods to hold the shelves in place and quickly move them without screws. I would want to experiment a little with how to hold the dowels in place (cotter pins?), but shouldn't be much trouble for quick/dirty adjustable shelves.
I would build one but will use plywood and 2x4 lumber for verticals. Pine shelve holders, splits easy and is not structural enough for the weight of all my books.
Will bolt the whole thing to the wall studs with 1/2" bolts and washers.
Did you make your shelves a specific size so that they fit directly in the studs in the wall?
He's from the UK so very rare to have studded walls. "Rawl plugs" is the giveaway plus they have gone metric.
The 1 x 6 timber was exactly 32mm wider than the 2 x 4 timber so it is a very secure fit to the parts mounted to the wall. It was just by chance that's what I had. If you had wider boards you may have to cut them down to fit but for this, I didn't have to
Very useful! When I saw the last images holding long boards, it became obvious why you added a top plate to the brackets. It could be adapted for book shelves, wall-mounted desks, model train shelves, etc.
I have difficulty lining up the chop saw blade with a pencil line - I would probably make a simple jig to keep my fingers out of the way - just a large scrap piece cut at the desired angle and clamped down. Then set the good piece against the jig.
Now I want to see how you made that pretty chop saw table (hint hint)
Check out my other Instructables for a full break down of how I made it!
Got it. Nice worktable. Love that Kreg fastening system. Now I understand why a 3-level platform for the miter saw is needed - similar level show in other builds.
Might be interesting to use French cleats on this project. Support is already built in and the cleats could make the shelves adjustable.
