Quick Easy Waterproof Flashlight using an inner tube
 by ElusiveGreen
Contest WinnerFeatured
Electricity and water are never a good thing to mix, but you never want to be caught out in the dark without a flashlight. Whether you're just a hiker and worried about rain, or prefer to canoe or kayak and are constantly worried about ending up in the drink, a waterproof flashlight is just as cheap and easy to make, as it is to buy.
Disclaimer: Water and electricity are a bad combination. It can short out your equipment, and depending on what it is it can give you a decent jolt. While I have made and tested this flashlight take everything said with a grain of salt and some common sense. Always be careful when putting dangerous elements together.
Step 1: What you need
A few things to consider. Stay away from self sealing tires. They are lined with a slime that is forced into punctures where it will harden. Needless to say, that would become a horrific mess if you try to cut it. If you don't have any tubes with holes in them you could always consider upgrading and then having the old inner tubes to play with, and if you do have a tube with a hole then you of course want to use a section that isn't pierced for this project.
Materials:
Flash Light
Inner tube from a bicycle
needle and thread
clear plastic bag
super glue
Tools:
Utility knife or scissors
clamp
snowluck2345 says: Dec 19, 2011. 10:38 PM
any tips on getting the innertue on? mineral oil? is really hard to pushup it on.
godbacon in reply to snowluck2345Jan 9, 2012. 1:54 PM
roll it up and roll it on like a woman's stocking.
annagail says: Nov 5, 2010. 5:32 PM
Seems like you'd need a flashlight with a button toggle rather than a switch or twist style on/off mechanism.
ElusiveGreen (author) in reply to annagailNov 6, 2010. 9:24 AM
Very true. Something I hadn't mentioned because I did have the push button design myself. To note, though: having this design, there is some flexibility in the tubing. It would be my assumption that it may not affect a slide switch, or even a twist. I have managed to adjust the focus of the beam by twisting the cap while it is in the sleeve.
Monkeyboy13 says: Oct 17, 2010. 9:14 PM
so water doesnt leak in from the front lens of the light?
ElusiveGreen (author) in reply to Monkeyboy13Oct 18, 2010. 7:09 AM
There is a thin piece of plastic, like a ziploc bag, that is inside the head of the flashlight, covered in step 5. It covers the bulb and actually passes back to the threads where the head screws on. With the head screwed on it seals itself. It may leak in from the front of the lens, but no water gets into the wiring.
I actually would've preferred the plastic to be external, but I ran into some difficulty with keeping it on, and pulling the rubber over it, so I adapted slightly. I'll try to get around to taking the pictures for that part.
redcore4 says: Oct 17, 2010. 4:07 PM
could you use a hole punch (like the ones you use to file papers to make the hole? a more perfectly round hole will handle stresses better (as well as being one less step for playing with knives), and be less likely to tear. it's been years since i last played with an inner tube, so i'm not sure if the rubber will be too thick for this?
ElusiveGreen (author) in reply to redcore4Oct 17, 2010. 8:50 PM
I think it would be more of a matter of can you get the punch around it. The rubber seemed to cut pretty readily with scissors and the like so that shouldn't be a problem.
prodo123 says: Oct 17, 2010. 12:43 AM
What if you have one of those goo-filled tubes...and need to replace batteries? GROSS.
Cyberscann54 in reply to prodo123Oct 17, 2010. 11:57 AM
use non lubricated condoms
JamesRPatrick says: Oct 14, 2010. 4:49 PM
Nifty! Have you tried welding the end together, or does cement work better?
BtheBike in reply to JamesRPatrickOct 17, 2010. 10:18 AM
if it could be charged while sealed by induction . That might be cool . The gas produced by batteries should be taken into account also in a 100% sealed app . maybe a 1 way valve ?
ElusiveGreen (author) in reply to JamesRPatrickOct 14, 2010. 5:26 PM
I didn't try welding, because the only decent tool I'd have for that is a soldering iron, and I'd be afraid of not getting a consistent seal throughout. Maybe with a hot air gun that would work. You'd just want to make sure its uniform throughout.
prodo123 in reply to ElusiveGreenOct 17, 2010. 12:44 AM
I think he was being sarcastic.
JamesRPatrick in reply to prodo123Oct 17, 2010. 7:39 AM
Nope. You can weld metal, plastic, rubber, all sorts of things. Pretty much anything that melts(chocolate!).
prodo123 in reply to JamesRPatrickOct 17, 2010. 12:55 PM
lol attempt an arc weld on chocolate!
ElusiveGreen (author) in reply to prodo123Oct 17, 2010. 8:58 PM
Now that would be an awesome instructable
JamesRPatrick in reply to prodo123Oct 17, 2010. 4:11 PM
LOL no.
ElusiveGreen (author) in reply to prodo123Oct 17, 2010. 6:35 AM
I think when he said welding he meant melting the rubber together compared to gluing it. Not anything with welding the flashlight. So it is a good idea if you have the tools to do it right.
Spokehedz says: Oct 17, 2010. 9:22 AM
This is a nice trade off between a permanent solution like filling the flashlight with mineral oil (As seen HERE) and the ultra-quick solution that I used to use which was a non-lubricated condom with the end tied in a knot.
Kudos!
CHRISPX says: Oct 17, 2010. 7:09 AM
I reckon you could do this just as quick using a decent condom. You'd probably have to change it when the batteries went flat mind!
kraM says: Oct 14, 2010. 6:57 PM
i did this to my mag light (the rubber over the switch was missing when i got it)
ElusiveGreen (author) in reply to kraMOct 15, 2010. 6:14 AM
I still had the rubber over the switch, but I was pleased that the inner tube actually hasn't effected it. That was my biggest concern; that it'd get stuck in on or off.
kraM in reply to ElusiveGreenOct 15, 2010. 7:56 PM
cool, any idea how to waterproof a min mag? heat shrink tubing maybe?
bertus52x11 says: Oct 15, 2010. 2:52 AM
You've got my vote!
brunoip says: Oct 14, 2010. 4:27 PM
clever :]
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
