3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Quick Firestarter
Quick Firestarter
This is a very simple firestarter made out of old candles, some dixie cups, and toilet paper rolls.
Step 1Melting the wax
Melting the wax
This should be self explanatory. you melt the wax and fill up the little paper cup. leave about 1cm of space between top and wax.
21 comments
Apr 24, 2010. 1:34 PMsparkster1 says:
You could add some powdered milk and it will start a fire with a flash!
Feb 8, 2010. 12:26 AMtrike road poet says:
One gimmick I use is those small gift boxes like jewelry stores have.  I fill them 3/4 full of wax, add some sawdust and a cotten string laid over the middle of the box from side to side. I then fill the box the rest of the way with liquid wax.  Once cool, i worl a little wax from a candle over the string ends by pulling the string across the candle.  Fold the string into the box and put on the lid.
To use, open the box pull the two 'wicks' up and light.  The improvised 'candle' lights and the large flame is easy to start the fire with.  I use a heavy stick or log fragment on each side of the box and pile the kindling over the candle.  As the flame ignite the small stuff, add the heavier stuff in a log cabin structure over the burning kindling.  One very important point, use a small narrow stick to keep air passages open as the fire starts to keep the flames fed with air as the wood pieces come to ignition temps.
Jun 10, 2009. 5:31 PMtyty100 says:
Spray some wd40 on it to start it easier and u will not waste ur lighter.
Jan 15, 2009. 2:14 PMPhil B says:
Someone told me a very good fire starter is a bag of Fritos corn chips large enough to serve two or three people. Just open it and place a lit match inside it.
Apr 21, 2009. 8:12 AMsharlston says:
why not just cut a paper cup in half the put sawdust and cotton balls and use a q tip as the wick it works
Feb 1, 2009. 9:42 AMcx420ns says:
someone told me that's how all the convenience stores "accidentally" catch on fire <.< >.>
Nov 11, 2009. 11:15 PMmojobo1 says:
It's the oil. Potato chips have lots of oil.. So they're pretty flammable.
This is more portable, but I like newspaper. (Wood stove is my only heat source.. Start a fire in it every morning)
Also, I think letting the wax drip onto the wood helps. Think of a candle.. The wick is IN the wax so it burns a lot longer. If the cardboard burns up and theres still wax, there will just be a big puddle of melted wax.
Wax doesnt burn easy by itself (has to be really hot), but if its on something else like wood/wick/string/etc, it burns better.
Jan 17, 2009. 7:21 AMimshanedulong says:
Bet it would work better if you crushed the chips!
Jan 15, 2009. 3:00 PMmynameisjonas says:
....... what?
Jan 15, 2009. 3:02 PMtech-king says:
then the grease inside of it goes fwooomp
Jan 15, 2009. 4:18 PMPhil B says:
That is my understanding of what happens. I have not tried it. The person who told me has a friend who does it quite often. I like Fritos too much and do not start fires very often.
Jan 18, 2009. 6:43 AMknexsuperbuilderfreak says:
just use one of them i can start a bon fire with 1
Feb 5, 2009. 5:51 AMEmmettO says:
This is a good way of doing it. Try this though and see how you like it. Take a dixie cup, fill it with cottonballs and if you have sawdust you can add that too. just make sure the cotton is on top to act as a wick. Then add molten wax to the dixie cup. Put it under your logs and light! The first time I did this, I used a full sized paper cup, flames were rocketing out of it for two hours! It was cool, but overkill. Next I tried the dixie cup. It was just right, about a half hour of flame to get logs going. Later I tried just sawdust and wax (using an old muffin tin as a form) that worked, but the wax would tend to melt all over and then ignite. The paper cup helps keep the molten wax in one place.
Feb 15, 2009. 4:03 PMbylerfamily says:
The full sized cup was burning the wax vapors.I made a mini stove that burned wax vapors.
Feb 6, 2009. 8:40 AMmaruawe says:
I use a small amount of calsium hypochlorite and brake fluid . About two ounces of the calsium hypochlorite and half ounce of brake fluid .. I set the wood for the fire and then put the dry powdered chemical in a hole in a piece of wood near the bottom pour on the brake fluid and step back away from the fire and the smoke, which is clorine gas(not good for you ), as soon as the smoke clears you are ready to cook what ever you want. I use this method during the winter because of the moisture from snow and the altitude in the mountains around Silverton Co. At over 9000 feet you want warm food and hot coffee as quick as you can make it. Ps don't carry both the powder and the brake fluid in the same saddle bag.. The trails are to narrow to scare a horse or yourself , just be careful
Feb 15, 2009. 6:43 AMmaruawe says:
calsium hypochlorite is pool shock (there are two types,read contents). Any pool supplies dealer should have it ( the smoke is toxic,chlorine gas)... any brake fluid should work never use this indoors.......the fire is very hot and bright I'm going to try to start a thermite fire with it and see if it will start thermite........ best thing I can tell you is BE CAREFUL WITH CHEMICAL FIRES use protection
Feb 2, 2009. 2:10 PMjhowen1 says:
I found that using a Frito corn chip works great, I saw it done at a bon fire i was at I laughed at first but then it works.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:MattandJora
