Introduction: Quick Formatting With Notepad and Word
If you copy and paste from the web, you frequently get a bunch of garbage and some bad formatting. The same can be true with PDFs and other such documents, and formatting each individual item is aggravating to say the least. When I was working on a project to organize and format questionnaires for a clinical psych lab, I ran into a lot of issues when it came to copying and pasting. I'm sure some people already know these tips and perhaps take for granted that not everyone knows how to do this, so this is for people who struggle with formatting and want an easier solution than painstakingly editing each line.
This Instructable shows to quickly format copied text for reuse on the web, for an email, or for a document using Notepad and Word (2003). Here is the source used in this example.
If you want to more clearly see the process, click on the "i" on each image and view the original size.
Step 1: Copy and Paste Into Notepad
Further Explanation:
- Open Notepad and the application/document containing the text you would like to format.
- Highlight the text and hit the CTRL button and the C button at the same time.
- Open the Notepad window and click on the white space.
- Hit the CTRL button and the V button at the same time.
Step 2: Copy and Paste Into Word
Note: This will help give you the raw text without the hidden formatting such as URLs.
Further Explanation:- Open Word and the Notepad screen.
- Open the Word window and click on the blank document.
Step 3: Removing Bullets and Numbering
Bullets and numbers (or really any sort of weird spaces or characters) usually have a rhythm to them, and you can remove these bullets/numbers using the rhythm to your advantage with the Replace function in Word. Once the bullets/numbers are removed, you can quickly go back through the text and add them again using the usual methods.
Copy the bullets/numbering plus any symbols and spaces that appear before each line of text.
Go to Edit->Replace (or hit CTRL+H).
Paste into the "Find What:" box.
Click on More->Special->Any Character or type in "^?".
Replace ^? for any numbers or recurring characters.
Leave the "Replace with:" box empty unless you are wanting to substitute for a character, format character, or text.
Hit Replace All and click Yes in the next box.
Repeat the process for double digit numbers by adding another "^?" next to the other.
Repeat once more for triple digit numbers if they exist.
At this point, you can add the bullets/numbering back using Format->Bullets and Numbering.
Step 4: Adding/Removing Paragraph Marks
For Adding Paragraph Marks:
- Go to Special->Paragraph Mark or type "^p" into the "Find What:" box.
- Type "^p^p" into the "Replace with:" box.
- Click Replace All and Yes.
- Type "^p^p^p" into the "Find What:" box and "^p^p" into the "Replace with:" box.
- Repeat until the replacements is 0.
Step 5: Regional Formatting
Highlight a portion of text you would like to format differently than the rest or separately from the rest.
Hit CTRL+H.
Enter your "Find what:" and "Replace with:" text, characters, or formatting characters.
Click "Replace All" and then "No".
Note: If you click "Yes", the replacements will be made throughout the document which would defeat the purpose of selective editing.
Step 6: Swapping Out Formatting for HTML Code
You can also use characters or formatting characters to insert HTML code. In this example, I will be adding line breaks for every paragraph mark.
Hit CTRL+H.
Type "^p" into the "Find what:" box and "< br > ^p" (minus the spaces) into the "Replace with:" box.
Step 7: Copy Back Into Notepad for Web Applications
Copy the text in Word and Paste it into Notepad.
Copy the text in Notepad and Paste into the application you intend to use for publishing if other than Word.
Step 8: Formatting by Hand
Not everything can be done by replacement. You will need to format by hand or edit portions individually.
