3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Quick Igloo
Quick Igloo
Make a big igloo in 3 hours using a snowblower, some trash cans and a tarp.
Step 1Make a pile of trash cans
get about 5 trash cans with lids together and tie a loop of rope onto a few of the trash cans for easy removal from the igloo
51 comments
1-40 of 51next »
Nov 26, 2011. 2:41 PMTechDante says:
a while back i saw one of teose ultimate survival programs where the contestants went and did teh norwegian army snow training (the british army still send troups to take this course) part of teh training was to build a snow cave after a gruling hike. their principle was to build two bed shaped shelves either side of a trough and then a dropped down entrance like @orangewood mentioned. This made the chance of sufforcating less as the excess CO2 went out of teh doorway and the heat was kept inside. I cannot remeber if they built in an air hole above the door but this would seam logical to me as you would neeed a new supply of air as you were converting it to co2.
Aug 17, 2009. 6:12 PMdaelans says:
you know what i think would be waaay easier then this, just take a tent, a normal camping tent, right, and then leaev it out over the winter, and the snow falls on it and presto. but youd need some supports cuase tents arent that strong at all.
Jan 23, 2011. 9:34 AMBlaaken says:
actually, if the snow builds up on it slowly, the snow would hold itself up so long as the tent is kind of small.
Jan 16, 2009. 2:00 PMfroggyman says:
I do believe what you made is a Quinzhee, not an igloo(the differences are marked on wikipedia). Just putting that out there
But still very cool, if you want to have more "fun" you can just skip the garbage cans or gear and just hollow it out all the way.
I think i will try this method the next time I build one.
Jan 23, 2011. 9:31 AMBlaaken says:
Well, when there are specific meanings on words and people don't know then and use the words wrong, it's not an opinion, it's stupidity or laziness
Jan 5, 2010. 2:59 PMdie_dunkelheit says:
No, actually Quinzee and Igloo are very specific words which describe to very different structures. The Igloo is made up of cut blocks of naturally set, and much more dense snow, whereas the Quinzee is made of loose hand piled snow. Also, the Quinzee is a mound which is then dug-out, and the Igloo is built with an internal cavity. Igloos are also far more structural and do not sag like Quinzees do.
Dec 8, 2009. 6:27 PMH20 says:
I am getting 3-6" of snow right now.  in the morning I will try this! :}
Jan 13, 2011. 10:45 AMbakumaster117 says:
i have 16 inches of snow!!!!!!
Nov 1, 2010. 7:57 PMshenzer says:
has anyone tried misting the walls with water to sloidify them?
Feb 29, 2012. 1:05 PMAlgag says:
yes it works but BE FAST....you need to be spraying water nearly constantly or the hose will freeze
Dec 26, 2010. 10:13 PMGerrles says:
i only have 2 trashcans will that work??? What else can i use to replace the trash cans
Jan 9, 2009. 8:56 PMalex-sharetskiy says:
cool! too bad i don't have a snow blower, or snow for that matter something i'll have to try!
Dec 2, 2010. 11:08 AMcarpe_noctem says:
Just use a shovel. I used to make one of these every year.
Sep 25, 2010. 7:28 AMScreamo says:
Who needs that? get a house. or at least a cardboard box :)
Jan 30, 2010. 5:06 PMPikminRed says:
WHERE DO YOU GET A SNOWBLOWER!!
Oct 7, 2009. 8:22 PMPikminRed says:
 GRR!  I wish it snowed enough where I live! It never snows in lorda though, IM lucky not to live there. ( Just think It doesent snow in Florda..  But sometimes it snows in Africa?!?) Florda is nice for a vacation though! Its only like a 16 hour drive from here.
Jan 9, 2009. 1:58 PMve2vfd says:
Cool instructable! By the way it's called a Quinzee, a native Athabascan Inuit word for "snow cave". An Igloo is made of blocks piled up into a "dome", a quinzee is a dug out snow mound. My Scouts build a quinzee every winter and sleep in it. When built properly, it never goes below zero inside the quinzee. Also remember to naver make your door facing into the wind :)
Aug 17, 2009. 6:10 PMdaelans says:
one time, i was camping, im in boysouts, and one of the scoutmasters brought like 5 square things like brick molds, and we had the whole troop, almost, aking turns and we built a whol igloo like that, dont reccommend it, it wast sturdy, it took hours and it was only big enough for like 1 person to curl up in. it was fun till the end and we realized we wouldnt be able to actually go in it.
Jan 9, 2009. 7:51 PMthe_burrito_master says:
I once built this HUGE one (by hand) it had a hallway ,well more of a crawl way lol. it was so strong you could ride a sled down it. I never dug out the walls enough so you could not fit in it without curling up.
Aug 17, 2009. 6:09 PMdaelans says:
Aug 17, 2009. 5:23 PMFoehammer358 says:
the priciple for the door is that cold air descends and hot air rises, so if the entrance is lower thank the floor, it make a sink, and keeps the cold air out.
Jan 9, 2009. 8:10 PMwupme says:
Did you know that German "Gebirgsjaeger" (military montain special forces, trained to fight in the icy mountains) use a technique thats nearly the same? Well instead of barrels the use 5-6 six Soldiers wo "form" the inner part with a Tarp over them. I think if your in war, your probably gonna be short of barrels ;)
May 15, 2009. 4:09 PMextrordinary1 says:
CD's work great for this, with the hole in the center to let you see the reflection to aim it.
Jan 9, 2009. 8:25 PMve2vfd says:
We just pile our backpacks and put a tarp over them :) I'm not sure I'd like to have snow piled on me!
Jan 10, 2009. 1:07 AMGeekGod says:
Ditto that here.Same basic method I learned as well. Pile up whatever equipment you have plus any convenient filler in the local area (usually more snow). Never considered using people and not so sure I'd be keen on being buried either. But whatever works in a survival situation I guess :)
Jan 23, 2011. 9:37 AMBlaaken says:
if there are multiple people and something goes wrong, it would be a simple matter to just busty out of it.
May 12, 2009. 8:39 AMthe_burrito_master says:
I found the picture of mine. I made this like 6 years ago.
May 12, 2009. 8:41 AMthe_burrito_master says:
sorry it's so small I messed something up.
Feb 2, 2009. 2:19 PMorangewood says:
One thing you might want to consider is digging the entrance down below the wall (if the snow is deep enough) and up into the igloo. I forget the exact principles, but it keeps the wind out and the warmth inside. If you search google for "How Igloos Work" you'll find a How Stuff Works article about it. Also, when I was a kid I made "windows" by freezing ice in a baking pan, then building them into the walls.
Jan 22, 2009. 11:17 PMcog66 says:
Love it. Brings back alot of good memories from my childhood.We used to dig ours out of the huge piles of snow from where the plows pushed it up. We had as many as 4 different rooms in them befor.You can heat these things with a candle and be quite comfy,just remember to have ventilation.I do however have to disagree with blazing on one thing.I think the most important resue device is your mind.To me that is the most important survival tool.Great stuuf though and thanks for the memories.
Jan 13, 2009. 6:02 PMNinjaSloth says:
Doesn't CO2 weigh more than O2, therefore, causing the CO2 to remain trapped inside? Would it help The problem if you would dig some ground level holes in the iglue or would it just make it worse? It always gets hard to breath in the snow forts I've made and I'm just wondering if it would help more to build a chimney or to dig ground level holes.
Jan 16, 2009. 1:00 PMWafflicious says:
Hmmm maybe it's because the CO2 is warmer? That's a good point
Jan 12, 2009. 1:36 PMdchall8 says:
Do you mean 0 degrees C?
Jan 11, 2009. 6:13 AM=SMART= says:
Wow thats awesome !!
Jan 10, 2009. 1:45 PMPlasmana says:
Wow! That is really cool! i always wandered how to easily build a large igloo... Unfortunately, I had less than a inch of snow in my area... ;-(
Same :(
1-40 of 51next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
7
Author:blazingpencilsdotcom
