Step 2Building The Base
The flat part of the base was made from 1/2" plywood - we used 12" wide and 10" long to fit our mini-notebooks, but the size can really be anything here. We drilled the 1/4" holes to match the standoff and Wheel Kits - 1/2" from the side and 2" apart as before. The leading edge matched the standoff, so the tires stick out just a bit. We did that to have them hit the wall before the base, but that's not too big a deal. On the top of the board, we used a counter-sink bit to make room for the flat head of the 1/4"x20 bolts (2.5" long).
The bolts need to be actually a bit shorter than 2.5" to fit just right, so we just cut about 1/4" off the ends with a Dremel tool. If you use 3/4" plywood, they might fit without being cut off.
Once that was complete, we bolted the Wheel and Motor Kits to the base.
comment
Add Comment
Add Comment
