Quick Start Guide: Printing With Ultimaker 2
Published
Introduction: Quick Start Guide: Printing With Ultimaker 2
About: This work is not for us. It is for the future. And robots. That is, each of these pieces takes for granted that computers will outlast their makers, that technology will supplant humanity, and that craft sho...
This tutorial will get you up and running with your Ultimaker 2
You will need:
-a 3d model in an STL format
-Ultimaker 2 (or similar)
-SD card or cable adaptor for the Ultimaker
Step 1: Are You Going to Tether You Computer or Use an SD Card
I strongly recommend you to do the latter.
3D printing takes HOURS unless you are printing something really small and simple in which case it will take an hour. Plugging your computer in USB will mean being stuck to the bot until the print is finished. Now that you have decided to use the SD card reader lets mover on.
Step 2: Download Cura
You will need to download a program called Cura in order to convert your STL file into a bot readable file. This is available here:
http://software.ultimaker.com/
Once you open the program it will ask you which bot you are using in order to give you a digital visualization of your particular build platform.
Step 3: Import Your STL
Click LOAD in the top left hand corner and choose the STL you would like to print.
Step 4: Customize Your Settings
In order for your model to print correctly you will need to customize the settings.
Resolution- Do you want it to be faster or prettier or a happy medium? This depends on what you will be using your printed object for.
SUPPORT STRUCTURE- This is the important one.
RAFTS- Like a life raft for your print, this layer of plastic is printed first and sits under your print and keeps it from peeling off the build plate during printing. If can be removed when the print is complete. The raft is useful if your print is long and flat because some warping may occur during printing due to temperature fluctuations.
SUPPORTS - Supports are what they sound like. They are there to keep your print from becoming a mushy pile. Remember there is no anti gravity device in your bot yet. (disregard if this is the year 3014 and no longer the case) Everywhere printing will occur where there is nothing underneath to hold it up will need to be supported. By checking the support box the program will generate a removable scaffolding for building your print.
ADVANCED SETTINGS
If you are printing something complicated you should turn down the print speed. Using the EXPERT dropbox choose FULL SETTINGS and the dialog box on the left hand side will change. Now you have full control over all of the settings. Find the PRINT SPEED MM/S option and adjust the speed. I believe the default is 50 mm/s for more complicated objects I suggest 25mm/s but you have to experiment for what works for your print.
Step 5: Export Your File
Export the file to the SD card by clicking the SD card in the top left corner. It will give you an estimation of the print time and material usage.
Step 6: Prepare the Print Bed
Put a thin layer of all purpose glue stick glue on the print bed. This will act as grease on a baking pan and allow the print to be easily removed when the print is finished as well as keep it in place during the printing process.
Step 7: Printing!
Insert the SD card. Use the toggle to select print and push in on the toggle button! Use the toggle to select your file. The printer will spring to life and align itself only to pause for preheat for a few minutes. You can monitor the heating progress in the bar on the screen.
Step 8: Watch Your Bot Print for 15 Hours!
May not be 15 hours but also may be more! 3D printing requires patience so find your inner zen and sit tight.
Step 9: Get Excited!
It is almost done printing!
Step 10: Remove Your Piece
Gently pull your piece off the platform. Make sure the platform has cooled first otherwise you may get some warping on your print while pulling it off the platform. If it is difficult to pull off remove the glass platform from the printer by turning the two front metal tabs toward you.
Step 11: Clean the Platform
Make sure you remove any plastic strings and extra glue so the next person has a clean platform.
Step 12: Print Complete!
You survived! Congratulations! Think about it... They call this "rapid" prototyping. Imagine what it was like before 3d printers.
    • Microcontroller Contest
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    5 Comments
    The Ultimaker 2, to my knowledge, will only print GCODE files, so you need to use a slicer like Cura or Slic3r to transcode it.
    No, we need use Cura(software) first.
    great intractable. wen done tnx
    Nice tutorial! Thanks for sharing this.
