Use Hair ties or an O-ring as a quick and easy as well as inexpesive way to add head lights to your Bicycle.
You can mount inexpesive or expensive mini flash lights in either a top mount or bottom mount fashion.
Using any of the folllowing:
Hair Ties - use medium - 1/8 or so or even decrative Hair ties in this fashion to add some flair to your holder.
Regular Hair ties like the one shown in the below image cost around $1.50 a 20 pack at the time of this writting.
Hair ties however, do not last very long before needing replacing. The rubber inside breaks down and they strech out.
Besure to use two hair ties per light incase one breaks.
O-rings - for either of the below lights i used 2 1/2 inch I.D. 1/8 inch standard O-rings. again using two incase one breaks.
Rubber Snorkle keeper - Rubber Snorkle keepers are the perfect size for many mini flash lights and come in a variety of colors to match or add accents of color to your bike and attach easily using the same method. It's easier than trying to stretch it over the head of the flash light on some models so start as the rear or base of the flash light when attaching them to the flash light.
Twine - Yes you can use string or twine in this same fashion just add more wraps and tie it off
- great for attaching lights to a Bamboo bike or Bent plywood bikes.
Remove these ads by
Signing UpStep 1Attaching
Simple deside whether you want a top mount or bottom mount.
Postion the light above the handle bar for top mounted lights and
below the handle bar for bottom mount with the mounting material of choice in front of the handle bar.
As seen in the below image start at postion 1 and stretch the material up and over the handle bar (postiion 2)and
finally over the end of the flashlight (Postion 3)
Adjust the position of the flash light. (postion 4)
your done!
For top mounted lights follow the same - just go under the handle bar and over the flash light end.
Adjust and your done!
Unfortunately for me, though they lasted 4 months on the bike shown, once i put my Red Line lights on my Electric they were stolen a few days later.
Now i just have some cheapy flash lights. - Sure do miss my Red lines as they were perfect for head lights.
BTW - since this post - Red line flash lights came out with one that has the mounting attachment with it for mounting on your handle bars.
again thanx for the tip. You might want to try the silicone snorkle keepers i mentioned - they have the perfect size hole for some LED flashlights.
